Carb Trouble
Posted 06 April 2009 - 05:50 PM
mark
Posted 06 April 2009 - 06:01 PM
Dont worry about smoke or anything just yet, that's normal if you've stripped your engine down, its probably just burning any oily fingerprints or excess gasket sealant ect away...
How long have you had your engine running since you've fired her back up? You may just need to let it get warm and run everything in so everything can settle again.
Edited by minitomfoolery, 06 April 2009 - 06:03 PM.
Posted 06 April 2009 - 07:51 PM
cheers
Posted 06 April 2009 - 07:57 PM
there is oil in the dash pot as well. the smoke thats coming out the back is thick and blue so i think its runnig far too rich. the problem actually stated in scotland after i changed the head gasket. once warm, the revs would die down as soon as im off the throttle. cold seemed to be fine. after i managed to get her runnin, it was only a day later that it wouldnt start. is a HIF carb the right one for a 998cc or should i look into a replacement part...?
cheers
Depends is it a HIF44 or 38?
