Cylinder 3 Missfire
4 replies to this topic
#1 gsb1486
gsb1486
    Just On Tickover
  • 5 posts
Posted 06 April 2009 - 06:08 PM
racing flame
1989
998cc
i have a missfire only on cylinder 3 all the time. i put new plugs, leads, condensor, coil, points, rotor arm, dizzy cap on it and it was fine for about 5 hours running time and then it just started running on 3.
any thoughts would be really appreciated
cheers
the head gasket was done recently too
#2 Pauly
Pauly
  • 4,213 posts
Posted 06 April 2009 - 06:12 PM
Do a compression test. Number should roughly be the same, even though the head gasket has been replaced has the head been torqued down properly? Could be that the head needs skimming.
Paul.
#3 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 06 April 2009 - 07:01 PM
if you are certain the ignition side is ok get a cylinder leakdown test done, a compression test doesn't really tell you anything.
why did the old head gasket go by the way ??
#4 stickycreambun
stickycreambun
  • 1,865 posts
Posted 06 April 2009 - 07:02 PM
why did the head gasket get done recently? compression test would be good. are all the electrical bits fine, no loose connections or anything?
#5 Frog
Frog
  • 492 posts
  • Local Club: Blakehill Mini's
Posted 06 April 2009 - 07:15 PM
racing flame
1989
998cc
cheers
Could be a number of things, Why was the head gasket done, was the head de-coked & cleaned, did you inspect the head, did you have the valve out, could be a small airline crack in the head, could be a poor seating valve, a compression test would give you some idea of a problem cylinder.
