Safe Jacking Points
Minitrio
, Apr 07 2009 12:25 PM
8 replies to this topic
Posted 07 April 2009 - 12:25 PM
Novice question I know, but where is the best place to firstly put jack and secondly put axle stands to jack up front of mini?
Need to change gear selector rod seal and disconnect the exhaust from the inlet manifold, to change the head gasket.
Photo's would be a bonus help.
Posted 07 April 2009 - 12:45 PM
Bump
Posted 07 April 2009 - 12:48 PM
jack it up on the front subby and put stands under front subby too.
job done.
job done.
Posted 07 April 2009 - 12:49 PM
Underneath the subframe. At the front, i'll put the jack under one side, raise it up so its high enough to put stands under the front of the subframe. Same with the back. Remember to use chocks
Posted 07 April 2009 - 12:51 PM
everytime i see that dancing bannana i lolUnderneath the subframe. At the front, i'll put the jack under one side, raise it up so its high enough to put stands under the front of the subframe. Same with the back. Remember to use chocks
Posted 07 April 2009 - 01:17 PM
Cheers guys.
Posted 07 April 2009 - 03:31 PM
The stands shouldn't be under the front of the subframe, they should be directly under the vertical member that forms the spring tower, but not on the flat section under the lower arm which will deform. That's the strongest part of the frame and where it is designed to take the load. Jacking or supporting the car by the tie rod mount often results in damage and isn't very secure.
Posted 07 May 2009 - 10:47 PM
This thread would be much better with pictures! I'm also worried that I'm jacking my Mini up in the wrong place and wouldn't mind a visual pointer in the right direction
Posted 07 May 2009 - 11:01 PM
Best i can do at the moment il get some more tomorrow if i remember.
