Spi Distributor Refitting
4 replies to this topic
#1 Mattl
Mattl
  • 588 posts
Posted 07 April 2009 - 07:26 PM
I am rebuilding my SPi engine currently. How do i refit the distributor with regards to timing. I know the ecu controls the igntition timing but there must be some degree of static timing that i need to for the engine to run. Anyone know how to fit it with regards timing?
Thanks, Matt
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 07 April 2009 - 10:17 PM
Set the engine to TDC on number one cylinder with both valves closed.
Fit the distributor drive so the slot is vertical. Fit the distributor, fit the rotor arm.
Now then, this is the important bit. Note which way the rotor arm points, fit the dizy cap and mark the body of the distributor that lines up with the closest plug lead to which way the rotor arm points, this will be noted as plug number one. Remove the cap and then align the mark on the distributor body with the center of the rotor arm. Tighten the clamp , fit the cap, connect the plug leads anti clockwise in this order 1,3,4,2 making sure plug one is connected to the dizy cap where you marked the distributor.
#3 Mattl
Mattl
  • 588 posts
Posted 08 April 2009 - 05:21 AM
Thats a great help thanks! Espescially the bit about the dizzy drive slot and i forgot the dizzy runs anti clockwise!!
Just one thing...after i posted i found the bit in haynes that suggests i fit the dizzy drive slot horizontal and once the skew gears engage its at about 30-45 ish degrees diagonal and then to fit the dizzy to that.
Does the slot need to be horizontal or vertical? I know haynes isnt faultless you see and that it could be wrong and now im confused at which it should be. lol
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 08 April 2009 - 11:04 AM
It wont matter. However, fit it how the haynes book describes, then, to everything else I described
#5 Mattl
Mattl
  • 588 posts
Posted 08 April 2009 - 12:18 PM
Brill, Thanks Sprocket. Will have a go tonight!!
