Hitting The Rocker Cover
7 replies to this topic
#1 mjpuds
mjpuds
  • 337 posts
Posted 08 April 2009 - 11:24 AM
ok just swapped over to a set of 1.5 roller rockers , the red ones, i bought these ages ago 5 years when i ad them fitted on one of my old minis,
now my problem is im sure the springs are hitting the rocker cover. i can sort of remeber something about a spacer.. but not sure..should i just remove some of the inside of the rocker cover..
any help would be nice..
#2 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 08 April 2009 - 12:20 PM
What rocker cover have you got? It's possible the rockers are touching in their extended arc.
Try one of the big square rocker covers from minispares or similar.
Dave
#3 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 08 April 2009 - 12:21 PM
I have one of those rocker covers doing nowt in the shed if you want to buy it.....
#4 Wil_h
Wil_h
  • 3,244 posts
Posted 08 April 2009 - 12:58 PM
Quite a common problem. Standard steel ones should clear and MG metro ones too. I have to tap mine back slightly once it's nipped up to allow it to clear.
#5 mjpuds
mjpuds
  • 337 posts
Posted 08 April 2009 - 05:31 PM
hm strange the engine is a longman 1380, and still has the longman ali cover on,,and also when the engine was first made (6 years ago ) up it had a 1.5 setup fitted in it . it was only the last owner that swapped over to 1.3 ....and i guess i will look at removing some of the inside of the cover later just to see if that helps...
#6 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 08 April 2009 - 09:02 PM
I had the same problem, with my Titan 1.5 rockers. The rear end of the arm just below the adjuster nut was hitting the inside of the cover when the valves were shut. Even with the MG metro cover.
I tried to grind the inside of the cover, which probably would have worked but it took ages as I couldnt buy any alloy grinding Burrs locally. So in the end I gave up and bought the pukka Minispares rocker cover which allows clearance. It wasnt cheap, but beter to spend £50 and be happy that the rockers have proper clearance.
I guess its up to you, whether you want to mod the existing cover.
#7 mjpuds
mjpuds
  • 337 posts
Posted 12 April 2009 - 10:14 AM
ok i have removed some of the inside of the cover.. what a diiferance...sounds like a petrol engine not a desil...ok last question ..if this had been going on for a while what damage could of been done ...it was the springs of both ends hitting inside of cover..
#8 Ethel
  • 25,941 posts
Posted 12 April 2009 - 11:13 AM
You mean the exhaust valve springs on 1 & 4? I doubt it would have much effect as the springs themselves provide the force. Squishing them sideways might cause uneven wear on the valve stems and if the spring travel was stopped short the rockers and tappets could get a bit of a hammering. I'd imagine the inside of the rocker cover would show the most signs of damage if that was going on.
