Low Boost Turbo's
20 replies to this topic
#1 megabob
megabob
  • 207 posts
  • Local Club: South West Mini's
Posted 08 April 2009 - 11:29 AM
Hi all,
i've been thinking about boosting my mini for quite a long time and i've always been thinking about supercharging but latley people have been talking to me about low boost turbos.
Does anyone have any info on low boost turbos or any exprence.
Finally i've been tinkering with the idea of a weber turbo :) but just as a little curiosity, do you think it can be done?
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 08 April 2009 - 02:05 PM
A perfectly good solution for a highly efficient and moderatly powerful engine. Run 10:1 CR with a nice small turbo and 5 or 6 psi. With propper mapped ignition you could see great MPG and and supercharger like power delivery. Although the smaller turbo will compromise ultimate power.
#3 megabob
megabob
  • 207 posts
Posted 08 April 2009 - 03:06 PM
yeah im not going for silly boost, just somthing for a little extra power on and off the track and a good supercharger kit is around £2k where as a good turbo from ebay is around £200.
could you recomend a good little turbo for my 1293?
#4 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 08 April 2009 - 04:40 PM
i'd guess at a GT15/GT17 maybe?
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 08 April 2009 - 07:48 PM
Check out Wils budget Turbo build Here
You could use a Weber, there's a kit available to seal them for blow through use, but it's a lot of extra work & i doubt you'll see any gain over the HIF44, not on a low boost spec anyway.
#6 JetBLICK
JetBLICK
  • 1,222 posts
  • Local Club: myspace.com/worcesterretro
Posted 08 April 2009 - 10:33 PM
I didnt realise ther where kits to seal webers? There is a dellorto thats specified for boosting tho. Not sure i understand the benifits of using a weber type carb with forced induction tho, especially as surely the turbo will act like a big silencer before the weber?
#7 megabob
megabob
  • 207 posts
Posted 09 April 2009 - 08:18 AM
well i do have a HIF44 and a refurb kit which includes the turbo parts, could i use the kit to convert the standard HIF44 to a turbo?
#8 megabob
megabob
  • 207 posts
Posted 09 April 2009 - 08:44 AM
also could i use my filter king to regulate the fuel or would i need to get a turbo regulator
#9 Ethel
  • 26,093 posts
Posted 09 April 2009 - 09:25 AM
Yes you can convert a non turbo Hif, no you can't use a filter king. It's very similar but it doesn't sense boost to up the pressure to the carb.
#10 megabob
megabob
  • 207 posts
Posted 09 April 2009 - 02:06 PM
yeah did a little reading and i noticed that i would need a signal from the plenum to the regulator. well got my eyes on a few good turbo kits.
just a few last questions as their is more air being forced into the engine i assume that i would need a different needle for the carb?
Edited by megabob, 09 April 2009 - 02:07 PM.
#11 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 09 April 2009 - 04:41 PM
Yes you'd need to profile a needle as any "off the shelf" item is very unlikely to be spot on.
#12 megabob
megabob
  • 207 posts
Posted 13 April 2009 - 09:34 AM
damn i thought that might be the case, its such a pain that there arn't any good classic engine garages only ECU and modern garages around me
#13 ferrox_666
ferrox_666
  • 126 posts
  • Local Club: you tell me !
Posted 13 April 2009 - 09:48 AM
On reading Practical Performance Magasine, they turbocharged some old ass Bentley by blowing through its original 2"SU's by pressuring the float chambers and putting a pipe fitting connected to the plenum into the top of a FilterKing regulator to influence the top of the diaphram effectively making it a rising rate type for very little money! Yes it was a road registered car, No i dint think id trust it that much lol.
#14 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 13 April 2009 - 09:52 AM
you can profile the needle yourself if you buy a wideband lambda and gauge. there are some good guides on how to do it over on turbominis now by 'turbo tel' i think.
me and my mate both bought wideband kits and profiled our own needles, only went to the RR for power runs, i think phil does the same aswell?
the price of a wideband is around that of a proper RR setup by a decent garage, but its also a nice tool to keep an eye on so you'll know if the cars ever running lean on boost.
Edited by bud666, 13 April 2009 - 09:54 AM.
#15 megabob
megabob
  • 207 posts
Posted 13 April 2009 - 04:49 PM
i was thinking of getting a sensor so i can read the mixture throughout the revs. anyone know a good make to website to get the kit from?
