Filling With Grease
Posted 08 April 2009 - 07:05 PM
Year: 1988
Hi all, i tried greasing up the grease points on the mini today and i pumped quite alot in, but it didnt flow out like i expected and a lot squirted out the gun once it was removed like it couldnt come out while attached, i did poke the ball bearing with a screwdriver and they were free to move. Can the exit for the grease get blocked? or do i just need to keep pumping?
JD
Any non-standard parts that might be involved with the problem?
None.
Posted 08 April 2009 - 07:18 PM
Paul.
Posted 08 April 2009 - 07:20 PM
JD
Posted 08 April 2009 - 07:25 PM
Paul.
Posted 08 April 2009 - 07:26 PM
Many thanks
JD
Posted 08 April 2009 - 07:28 PM
Posted 08 April 2009 - 07:36 PM
JD
Posted 08 April 2009 - 09:48 PM
Posted 08 April 2009 - 09:50 PM
JD
Posted 08 April 2009 - 11:22 PM
Posted 08 April 2009 - 11:55 PM
Unscrew them and look through them to see if you can see light through the other end, if not then they are blocked.
That should not be possible. Every grease nipple I've ever seen has a small, spring loaded ball bearing that closes off the entrance hole so no dirt can get into the fitting when the gun is removed.
If you are able to pump the handle of your grease gun and it does not build up pressure... the nipple may not be blocked. You may be pumping into a very empty space OR the grease gun may have a big pocket of air in it. Regardless, try poking the opening of the grease fitting with a stiff wire and repeat trying the grease gun.
Lastly, if you're pumping up the rear radius arms on the suspension, it's not at all unusual for the grease tube INSIDE the arm to split. When that happens, you have to pump, and pump, and pump grease until the whole arm is filled with grease. That's an enormous volume to fill. So... if that's where you're pumping and no grease is coming out... just keep trying and don't be upset if you have to reload the grease gun.
Posted 17 April 2009 - 05:49 PM
I can vouch for this and it once took several grease tubes to fully grease the rear radius arms on the 98' Mini Paul Smith LE that a family member once owned. To be honest, a load of dirty water sprayed out just before the grease did.
So don't be afraid to keep pumping in the grease, as I'm sure it's far better to have a radius arm full of fresh grease than dirty water?
