Plug Lead Order
4 replies to this topic
#1 glenn27
glenn27
    Starting My Mini Up
  • 1 posts
Posted 08 April 2009 - 08:41 PM
Hi
i put a new set of ht leads on my mpi mini i made a note of where they came off,Then the dog ate it!, I found a picture of a cd i bought on ebay but it does not run right I put them on by memory instead it runs better but no 2 and 3 do not fire can any one tell me which lead goes on the distributor to which plug? thanks
#2 gumball
gumball
  • 57 posts
  • Local Club: yes
Posted 08 April 2009 - 09:37 PM
The firing order should be 1-3-4-2
#3 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 10 April 2009 - 11:20 AM
Hi Glenn, the firing order does not really help in your case, as it is an MPi; the plug lead connections to the coil run in the clockwise direction as; 1-2-3-4
Start with lead 1 being the closest to you and lowest connection on the coil and work round. (Coil connection 3, is closest to to spark plug 3.
(Cylinder 1 is the very right hand side of the engine as you look at it, please see photos of my MPi for reference !)
When swapping plug leads for a new set, it is better to change one at once, to avoid any confusion!
I have also bought some clip-on numbers for the ht leads - can just see them in the photo - white plastic bits near the plug end
Let us know how you get on.
HTH
Ryan.
Edited by L400RAS, 10 April 2009 - 11:24 AM.
#4 L400RAS
L400RAS
  • 2,479 posts
Posted 10 April 2009 - 11:36 AM
Although saying this, i have just looked in the rover maintainance manual and they show 2 & 4 swapped over to me:
However due to the system using wasted spark, the position of 1 & 3 are interchangeable, as well as 2 & 4 interchangeable !
I would go with rover, start with 1 = lowest and closest to you, and count round anti-clockwise 1-2-3-4
Ryan
Edited by L400RAS, 10 April 2009 - 11:37 AM.
#5 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 10 April 2009 - 12:49 PM
ignore the Rover workshop manual, it is wrong.
The best way to find out which lead goes to which plug, look on the coil pack itself. The numbers relating to where each lead should go, are marked on the triangular lugs around the fixing holes.
