Rust Around The Windscreen
Posted 08 April 2009 - 09:44 PM
Posted 09 April 2009 - 07:14 AM
Posted 09 April 2009 - 08:52 AM
plus any other nasty bits that come to light when you take the scuttle off
Posted 09 April 2009 - 08:57 AM
Posted 09 April 2009 - 09:02 AM
what's up with the door !!!
It's called a scuttle ( well the lower part ), but does look like the whole windscreen surround needs urgent attention... the only way to get round it, is to do it properly... which means, removing the wings ( A panels look like they need renewing anyway ) and replacing the whole surround for a new one..
Cost of doing the above, probably means the mini is worth nowhere near what the seller is asking....
I'm fairly sure many 'in the trade' would look at that as a lost cause and use it as a donor for spares.. for it to be worth it, it'd have to be seriously low mileage with comprehensive service history.
Edited by GuessWorks.co.uk, 09 April 2009 - 09:05 AM.
Posted 09 April 2009 - 09:15 AM
Posted 09 April 2009 - 09:29 AM
It will be expensive to replace the scuttle and doors!
How much are they asking for the car?
Posted 09 April 2009 - 09:31 AM
Posted 09 April 2009 - 09:32 AM
well if it's four figures, it's one figure too many...
Agree with you on that one mate!!
Posted 09 April 2009 - 09:39 AM
Don't go near it unless you want to reshell the thing.
It's likely that the sills and boot floor have gone too.
Find yourself another.
Posted 09 April 2009 - 09:41 AM
Unless you are a good welder already, i'd forget about this car. A body shop would charge hundreds, maybe over a thousand to do the welding and spraying.
And if the cars been neglected, chances are you'll find alot more rust is even more critical places.
I'd stay well clear unless its only a couple of hundred quid and you can weld.
Posted 09 April 2009 - 10:35 AM
I know they've never gone overboard with it from the word go in 1959, but were the late 1995+ Mini's not treated to the same level rustproofing from the factory that we saw on earlier models? Or is it down to quality of paint / steel that was used? In particular, do MPI's always seem to rust more around the windscreen, or is it me?
Regards
Edited by Goopster, 09 April 2009 - 10:49 AM.
Posted 09 April 2009 - 11:01 AM
I've seen MPi's with the inner dash rail completely shot too...
Posted 09 April 2009 - 12:55 PM
