Remote Style Gear Linkage
10 replies to this topic
#1 lawnmowercrap
lawnmowercrap
  • 896 posts
  • Local Club: Small 'n' Mighty Mini's
Posted 09 April 2009 - 06:14 PM
Hey all, I'm re-fitting my remote style gear linkage and its very stiff to get into any gear and I cant get reverse?
This is without the clutch being bled as I wanted to make sure I had gears before going any further.
Is there a way you line the linkage up?
Lee
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 April 2009 - 10:51 PM
Sounds silly but have you greased it? There's a grease nipple on the back of the diff housing for the vertical rod.
#3 lawnmowercrap
lawnmowercrap
  • 896 posts
Posted 10 April 2009 - 07:36 PM
No I havent, i'll try that now mate :thumbsup:
I've managed to get 1st,2nd,3rd, and 4th now but still cant get reverse?
Its is still lift and bottom right isnt it?
Its just when i try to lift the lever nothing happens.
I've fitted it so there is a washer ontop of the linkage, then the nylon bush sitting in the spring, with the little metal housing round it and then the cap ontop and tightened the bolts up as far as they will go. Is this correct?
Cheers, Lee.
#4 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 10 April 2009 - 07:48 PM
Do the Remote gearboxes have a lift for reverse? I'm not entirely sure myself.
#5 lawnmowercrap
lawnmowercrap
  • 896 posts
Posted 10 April 2009 - 07:52 PM
Thats what I dont know? but I still cant seem to find reverse. I have the 'H' shape through the forward gears but nothing for reverse?
Edited by lawnmowercrap, 10 April 2009 - 07:52 PM.
#6 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 10 April 2009 - 07:56 PM
Dont lift for reverse
Paul
#7 lawnmowercrap
lawnmowercrap
  • 896 posts
Posted 10 April 2009 - 07:58 PM
So it should just slide over then?
How come I cant get it lol
#8 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 10 April 2009 - 09:35 PM
Paul
I thought so
Reverse and 4th is quite close together from what I can remember on a remote
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 April 2009 - 06:29 AM
To select reverse on a remote ( and magic wand ) it's just a move to the right and down, however, it has a detent plunger and spring so it's more of a pop over to the right, you should feel it...
If you still can't select reverse, remove the nut on the front of the gearbox (like a sump plug) and then try you detent may just be stuck
#10 lildeucecoop72
lildeucecoop72
  • 112 posts
  • Local Club: Norsk Mini Cooper Club
Posted 19 April 2009 - 11:02 PM
I am having a similar prob after puttong a brand new remote type box in I couldn't seem to get the all the gears (only got 3rd and neutral), but after bleeding the clutch a couple of times I can get all the gears but it still a bit of a fight.
Not driven the car yet but does anyone know if this is a common thing after changing a remote box, that its stiff before you drive it?
#11 mister bridger
mister bridger
  • 911 posts
Posted 20 April 2009 - 09:11 AM
I've just replaced my clapped out magic wand box with a remote box (NOS) and it is stiff but slowly loosening up. I did forget about the grease nipple as well and haven't done anything about it as it looks a right pain to get at!
