Parcel Shelf
6 replies to this topic
#1 LESTA MINI
LESTA MINI
  • 492 posts
  • Local Club: 4th Gear Mini Club
Posted 10 April 2009 - 09:10 PM
Hi, i was just wondering how important is the parcel shelf to the minis structure as im going to put new speakers in it and just wanted to know if its ok to cut two cup size holes out of it. Dan
#2 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,728 posts
  • Name: Chris
  • Local Club: None
Posted 10 April 2009 - 09:12 PM
mines had 2 6x9 holes cut in it so it should be fine
#3 jayare
jayare
  • 2,093 posts
Posted 10 April 2009 - 09:24 PM
Later Minis had speaker holes as standard, so you should be fine. The panel IS structural and shouldn't be removed but speaker holes are fine,
JR
#4 LESTA MINI
LESTA MINI
  • 492 posts
Posted 10 April 2009 - 09:37 PM
cheers guys
#5 gumball
gumball
  • 57 posts
  • Local Club: yes
Posted 10 April 2009 - 10:51 PM
You could always add strenth to it by cutting 2 peices of MDF or PLY and put 1 peice on the top and 1 peice under (in the boot) and bolt all 3 peices together....
This will sandwich the metal parcel shelf and it will be a lot stronger + you will get LESS distortion.....
#6 Prawn
Prawn
  • 938 posts
Posted 11 April 2009 - 12:48 PM
I cut my parcel shelf out save for a 1'' lip around the edge, and I was amazed to find that the bulkhead remained TOTALLY solid, I expected it to flex a bit, but I was shocked to find it didn't flex one bit!
I've replaced the old gash shelf (full of previous speaker holes) with a nice alloy shelf bolted into place with 10 bolts around the edge
#7 LESTA MINI
LESTA MINI
  • 492 posts
Posted 11 April 2009 - 02:50 PM
CHEERS GUYS, after looking at the parcel sehlf and removing the old speakers im going to put a ew shelf in, so ill get this done tomorrow. thanks for all the help
