Dizzy/hif44 Na To Forced
19 replies to this topic
#1 AuDix
AuDix
  • 136 posts
  • Local Club: FmF Mini Club - Colchester
Posted 11 April 2009 - 01:02 AM
Hey I have a metro 1275cc soon to be 1293cc turbo conversion.
What do i need to do to the :
Dizzy to convert it to turbo ( or do i need to buy a whole different one)?
Hif44 can a na one be used or turbo rebuild kit ?
Will
(i have searched but couldn't find a clear answer)
#2 AuDix
AuDix
  • 136 posts
Posted 13 April 2009 - 11:27 PM
bumpy
#3 Wil_h
Wil_h
  • 3,244 posts
Posted 14 April 2009 - 06:45 AM
As far as I know you can't convert the dizzy, you need the turbo item. Well I suppose you could convert it but you'd need all the parts from a turbo dizzy, so it'd be pointless.
You can use either the turbo carb or rebuild an NA carb with a turbo rebuild kit.
#4 AuDix
AuDix
  • 136 posts
Posted 14 April 2009 - 10:18 AM
thanks man
anywhere sell turbo dizzy or am i going to have to car boooot it !
cheers
Will
#5 Wil_h
Wil_h
  • 3,244 posts
Posted 14 April 2009 - 11:00 AM
You'd be better investing in a mapped system like MegaJolt.
#6 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 14 April 2009 - 10:04 PM
Aldon will alter the advance curve in the dizzy for you, but as Wil said Megajolt is a far better option.
#7 megabob
megabob
  • 207 posts
  • Local Club: South West Mini's
Posted 15 April 2009 - 07:46 AM
i've been looking into megajolt, it seems that you cant get a complete kit you need to get the ford setup i.e coil, EDIS Ignition module and leads.
is their anyplace that can do a complete kit or do you have to source the parts?
Edited by megabob, 15 April 2009 - 07:47 AM.
#8 Wil_h
Wil_h
  • 3,244 posts
Posted 15 April 2009 - 09:28 AM
I'm sure someone could sell you all the bits, but you'll save money sourcing the bits yourself.
#9 megabob
megabob
  • 207 posts
Posted 15 April 2009 - 10:10 AM
trigger-wheels seems a good place for a large portion of the parts, and the pricing seems pretty reasonable
#10 AuDix
AuDix
  • 136 posts
Posted 15 April 2009 - 06:50 PM
does anyone have any information about how megajolt systems work and what is needed for i.e a turbo conversion.
Will
#11 megabob
megabob
  • 207 posts
Posted 16 April 2009 - 08:57 AM
i have compiled a small list to get me started on the turbo:
- Bolt-on trigger wheel
- EDIS 4 kit
- Megajolt ECU V4 kit
- Distributor blank plug
- AEM Gauge (Wideband UEGO Controller 30-4100, air/fuel mixture)
- turbo fuel pressure regulator
a good place to start is trigger-wheels if you go to the engine managment you can build a kit for the mini which is pretty much all you need to get you started with the megajolt
#12 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 16 April 2009 - 06:42 PM
You need the Megajolt unit, trigger wheel, crank sensor, Edis unit & a coilpack. The Edis, crank sensor & coilpack can all be removed from Fords from around 95-96 iirc ?
I'm going to be doing a writeup & fitting guide for my website as soon as i get time to fit mine onto my engine rebuild.
Phil.
#13 MRA
MRA
  • 7,607 posts
Posted 19 April 2009 - 06:29 PM
Did someone say blanking plugs ?
Also the advance curve for a turbo is pressure related rather than vacuum which is the norm for Naturally Aspirated engines........ However an ECU is the best way to go :) I did my first one over 13 years ago, and would not want to go back to a dizzy :(
And Trigger Wheels do have a fantastic new wheel specifically for the Mini :P
Edited by mra-minis.co.uk, 19 April 2009 - 06:30 PM.
#14 markking
markking
  • 107 posts
Posted 24 June 2022 - 10:43 PM
Phil.
Massive thread revival, did you ever get round to this Phil? I had a good search on your website but couldn’t find anything.
Thanks.
#15 Ethel
  • 26,791 posts
Posted 25 June 2022 - 12:12 PM
There was quite a few Megajolt topics. I think I even did a bit of a one myself. If you're starting from scratch also look at other options, like Sparkduino, MJ works well enough, but those EDIS bits will be ever harder to track down.
https://www.google.c...sclient=gws-wiz
