Mini Rear Light
6 replies to this topic
#1 Card
Card
  • 16 posts
Posted 11 April 2009 - 09:25 AM
hey i have got some clear mini rear lights
and its got this red lense that u have 2 put in and its a pain in the back side haha
i just wanted 2 no if i could get away with putting just a red bulb in its place ?
can anyone help me ?
thanks
#2 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 11 April 2009 - 11:13 AM
You can probably get away with a red bulb yea. I find though that most red bulbs look pink rather than red.
#3 GottaDesigner
GottaDesigner
    The Brains Behind TMF's Secret Santa
  • 1,394 posts
Posted 11 April 2009 - 11:56 AM
If you're talking about the red reflector that goes on the bottom of the lens, then I believe it's a legal requirement to have them.
#4 chappy
chappy
  • 1,253 posts
Posted 11 April 2009 - 12:44 PM
i think he's on about the clear jewel lenses.
should be good to go with a red bulb. they make a completely clear set, which is pretty much just that set without the red insert.
one thing to look at though are the mirror painted bulbs, when they're not lit they are silver, when they are they are normal red/amber/white and they'd look good in those lights.
sam
#5 redhotmini
redhotmini
  • 1,607 posts
Posted 11 April 2009 - 01:21 PM
red led replacement 'bulbs' look best in the jewel lenses. i used the chromed indicator bulbs, and the reverse light bulbs are just standard ones, so the rear light looks like its chromed entirely. had the same problem with the red lenses not staying in place - just use a couple of tiny pieces of double sided tape to hold it in place on the unit while you place the clear lens over it. once the clear lens is screwed down it should hold it all in place. i just didnt fit the red lenses in mine, too much hassle
#6 Card
Card
  • 16 posts
Posted 11 April 2009 - 08:05 PM
hey all thanks 4 all ur help im goin 2 get some red bulbs or led 1s :thumbsup: after the easter hols
so the lights should b so much better lookin when its done :D
thanks again
#7 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 14 April 2009 - 10:01 AM
i managed to fit the red lens easily, just use a brush of superglue on each side of the red lens then hold it in place for around 10 seconds, then put the clear bit over the top. works a charm.
