Molyslip
13 replies to this topic
#1 91neon
91neon
  • 447 posts
  • Local Club: abingdon owners club
Posted 11 April 2009 - 03:19 PM
my engines good just slightly noisy its done 43000 miles a mate suggested molyslip will improve the quietness and protect engine and gearbox i went to motor factors who sell two one for engine one for gearbox so first question is which one and does it actualy work. also when i change my oil is it wise to use flush or should i just drain it and top it up. im worried if i flush it i will cause leaks etc
and finaly are those oil syphons any good or should i just remove plug
thanks
#2 Ethel
  • 26,074 posts
Posted 11 April 2009 - 03:25 PM
I'd remove the plug, especially on a Mini. You want the heavy debris, sitting at the bottom, out.
#3 91neon
91neon
  • 447 posts
Posted 11 April 2009 - 03:29 PM
ok i will would you say flush it or not?
#4 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 11 April 2009 - 04:23 PM
if you want to ruin your engine then use a flush !!
if it's noisy then it needs a re build.
#5 stormintrooper
stormintrooper
  • 2,072 posts
Posted 11 April 2009 - 04:42 PM
hmm...am i missing something here with this flush business?
#6 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 11 April 2009 - 04:49 PM
most well mad engine are worth using engine flush when doing an oil change i have myslef for many years used engine flush as it removes all the crap and deposites from the engine and ensure the engine is clean for the new oil
many argue the detergents cause black death by lifiting crap off the sump base and and block the oil galleries
i myself have never had a problem and i normally do this when i first get a car
although with my mini currently leaking oil and the fact the engines bore is very worn i havent bothered as i do an oil change every month
when i rebuild my engine ill probs run 10w60 full synth
i have used engine slick 50 on my old saxo engine and it made it run alot quieter and sweater
so id use slick 50 engine treatment myslef but up to you if you change the oil often enough i wouldnt bother
#7 rosco454
rosco454
  • 908 posts
Posted 11 April 2009 - 05:06 PM
I wouldnt use synthetic oil in a mini engine.
20w50 mineral oil is about right for an a series.
#8 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 11 April 2009 - 06:06 PM
it's rubbish, simple as.
as for slick 50/thickening additives etc just read around on the net.
#9 rosco454
rosco454
  • 908 posts
Posted 11 April 2009 - 06:20 PM
Im a fan of just a simple oil change with good quality mineral oil,no flush and no magic juice!
#10 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 11 April 2009 - 06:23 PM
MAGIC JUICE lol
#11 1984mini25
1984mini25
  • 8,785 posts
Posted 11 April 2009 - 06:30 PM
Could be noisy tappets/ignition timing slightly out.
The key to a goob oil change is to get the engine/oil up to working temp, preferably by driving for it to circulate round the engine and pick up all the crap and then as soon as the engine is switched of the oil is dumped immediately while it’s still hot.
To minimise the time for the oil pressure to build up afterwards on initial start up, pre-fill the oil filter with fresh oil.
And providing you service the mini/change the oil regularly you shouldn’t get a build up of crap.
Edited by 1984mini25, 11 April 2009 - 06:34 PM.
#12 91neon
91neon
  • 447 posts
Posted 11 April 2009 - 10:31 PM
thankyou for all of your advice i will proceed tomo without a flush and with mineral oil
#13 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 16 April 2009 - 02:38 AM
if you use teflon (sliick 50) in a mini you will wear your baulk rings at a very much increased rate, your cylinder walls will become glazed and loose compression, becuse the mini shares its oil with the engine and box, to flush an engine buy some cheap 20w50 and run it for a few days/week and drain.
#14 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 16 April 2009 - 07:15 AM
The only thing you may want to consider is doing two changes, especially if it's really rough. Do an oil and filter change now, and then check the oil level and colour in a week or so, if it's still qutie dark consider changing again to get to nice clear oil, this will flush some of the remaining crud out of the system without getting carried away with random additives.
I always run on 20W50 in my mini's, Halfords do a rather attractive 'classic' oil, comes in a useful metal can too, brilliant for putting your old oil or other old fluids, (brake/clutch/etc) in to take to the tip afterwards.
Dave
