Sw05 Cam
Posted 13 April 2009 - 05:17 PM
Anyone else use this cam and maybe feel I am expecting too much from it? My engine just feels choked and restricted now.
Posted 13 April 2009 - 05:32 PM
SW5 are great for low (engine) speed torque, whilst the 286s prefer revs to get them going...
Um... what were you expecting exactly??Anyone else use this cam and maybe feel I am expecting too much from it?
Posted 13 April 2009 - 05:38 PM
A better choice would have been the SW10 which is similar in performance to a 286 but coming in a little earlier and having better idle emissions, etc.
Did you speak to Swiftune before you bought?
JR
Posted 13 April 2009 - 07:10 PM
Posted 13 April 2009 - 07:53 PM
Posted 13 April 2009 - 08:03 PM
I think the SW05 is more like a Kent 266, although I don't have the SW05 timing figures or curve data (does anyone have this data?).
Now, the 266 is very much like the MG Metro with similar timing.
Posted 13 April 2009 - 10:34 PM
Posted 14 April 2009 - 09:13 AM
There are a lot more things to consider than just swapping the cam. If your motor was built to make full use of a 286, just changing the cam will give you a crap result. A engine built with a 286 in mind would have crap volumetric efficiency at low rev's ie. your stage 4 head big ports low gas speed at low rpms. Where as the SW5 is designed to have high VE at low to medium rpms, so you've got a mismatch with a engine built for high rev's with a cam designed for lower rpms. What compression ratio was you running with the 286, it will most likely be too much for the milder SW5.
I didn't build the old engine and was lead to believe it was 10.5:1. Been a long time since I built a mini engine and truth be told I was in a hurry to get this back on the road after the oil pressure failure. Should have took an extra week and thought about what was going in and how they would work together. It's easy to swap the head etc and I think it will go a lot better. to be honest I have had standard mg metro engines that were just as fast and this is a 1380. The car is going for sale after the MOT next week anyway and going to concetrate on the other mini.
in short lesson learnt
Posted 14 April 2009 - 09:34 AM
Posted 14 April 2009 - 07:47 PM
As above - the SW5 is a really mild cam which is great in a daily driver that spends a lot of time in town. Compared to a 286 Scatter it will feel a bit lifeless and lacking the 'coming on cam' kick as you accelerate.
JR
didn't speak to them just ordered it on another guys say, should not have listened to him but he has been building mini sprint engines for longer than I've been driving. Decided to take the engine out and put the mg metro engine in for selling the car, going to look at a morspeed ph3 or sw10 for the engine and put it into the other mini.
