How To Make My Central Locking Flash My Indicators
5 replies to this topic
#1 tomsbluemini
tomsbluemini
    My Blue little monster
  • Area Managers
  • 1,498 posts
  • Local Club: LSMOC / Kentish
Posted 14 April 2009 - 12:12 PM
Hi Guys
As some of you know, I got a remote central locking kit for christmas, the one with the rover fob interface so that the rover immobiliser fob operates the central locking.
The car is a 1998 MPi, and AFAIK should have the bit that flashes the indicators when you turn the immobiliser on, but for some reason it didn't...
It did however have the extra socket for the plug on the alarm unit, so I bought one from a similar aged MPi.
I've had a look at a wiring diagram, and it looks like I need to find a big junction of indicator wires, one for each side. It seems to be where the wirs for the front, side and rear lights meet each other on each side...
My question - where exactly are these junctions of wires? I think that to make the indicators flash I need to put the wires from the alarm unit there, but there's so much sodding wiring on the car that I can't find them... I suspect that it might be behind the dash. I'm doing some more wiring behind the dash today, so if that's where they are, then i'll have another go at making it work while i've got the dash out.
Thanks in advance
Tom
#2 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 15 April 2009 - 04:58 PM
Bump???
#3 Ethel
  • 26,170 posts
Posted 15 April 2009 - 06:38 PM
Hazard warning switch is probably the most accessible .
#4 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 16 April 2009 - 07:15 PM
So how would I wire that then? There are 2 wires coming off the alarm unit - one for the left indicators and one for the right...
#5 MiNi FiZ
MiNi FiZ
  • 960 posts
Posted 16 April 2009 - 10:49 PM
hazard switch would be best, if you put the switch out from the panel there will be some wires going into the back of it, i cant remember off the top of my head, on my 77 mini i think one was green with a white stripe and green with a red stripe (left and right indicators) not sure if its the same on yours, although just get a multimeter, whack the indicators on and see which is which, but i just removed abit of the plastic sheathing and soldered the wires off your alarm unit on
Edited by MiNi FiZ, 16 April 2009 - 10:49 PM.
#6 tomsbluemini
tomsbluemini
  • Area Managers
  • 1,498 posts
Posted 17 April 2009 - 05:33 PM
All done and working... I ued the wires going to the indicators on the instrument panel...
