Temperatures Sensor
Posted 14 April 2009 - 02:56 PM
Hope this is making sense, it just seems silly to me.
There is a hole in the head where they put the sender on the carb minis as my friends is here. But there is no thread in it.
I would like to know if I could put one here if so how?
Any help or advise appreciated
Posted 14 April 2009 - 03:55 PM
The one that is linked to the ECU is under the throttle body.
Posted 14 April 2009 - 04:02 PM
The one at the bottom of the radiator is the thermal switch for the auxiliary electric radiator fan located under the left wing.I think the one at the bottom of the rad is just for the temp gauge.
Posted 14 April 2009 - 04:04 PM
Hope this helps
Rob
Edited by DaveRob, 14 April 2009 - 04:05 PM.
Posted 14 April 2009 - 04:05 PM
Thanks, was I right about the other one ?
Posted 14 April 2009 - 04:10 PM
is the one that costs about £42,
It is very true about a faulty coolant temp sensor causing lambda sensors to fail as I also had to change that.
Posted 14 April 2009 - 04:47 PM
I have only messed with the bottom one. Used it to drain and flush the radiator. Easier than disconnecting hoses. Connected a jumper to the terminals and with ignition switch on, the fan came on. Took the switch and checked with an Ohmmeter and it would close (0 Ohms) with boiling water. It supposed to close within a few degrees of that.The one at the bottom of the radiator is the thermal switch for the auxiliary electric radiator fan located under the left wing.I think the one at the bottom of the rad is just for the temp gauge.
I used WD40 to loosen the switch from the rubber seal the first time. Used a new seal for the final installation after the flushing cycles.
That is the extent of my knowledge.
Posted 14 April 2009 - 08:33 PM
Back to what rob was saying. My temp gauge in the car dose not go over half way (well iv not seen it). So does this mean it’s not working correctly and need replacing?
Posted 14 April 2009 - 10:22 PM
Mine is a 1994 Japanese spec Cooper. I have owned it for about two months. The needle would go to the center mark (I assume normal) on the gage. I have not seen it go above that, even when it idled for long periods while doing the flushing. I had not noticed the electric fan coming on either. That is why I checked the fan and the switch. I had very rusty water in the radiator and had me worried. Apparently, the cooling system was fine all along. I hope it is even better now.Thanks guy you been a great help.
In order to read accurately the temperature sensor as the ECU sees it, you need a code reader connected to the ECU. That is my next adventure. I bought a Yikes! Pickavant (shipping is a killer) code reader and I am waiting for its arrival from the UK. From what I can tell, the ECU sends an output to the gauge on the instrument panel for the temperature reading. But I believe that gauge reading could be messed up (bad gauge/bad wiring) and the ECU could still be getting good data from the temp sensor.
Edited by xrocketengineer, 14 April 2009 - 11:48 PM.
Posted 15 April 2009 - 08:02 AM
Hope this helps
Rob
Posted 15 April 2009 - 02:10 PM
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/grinwink.gif)
