Motorway Issues
Posted 14 April 2009 - 10:21 PM
Year:
On motorway journeys the car is losing power. Car is fine around town and when first joining the motorway car flies along. However after a couple of minutes 'spirited driving' the car starts losing power and has to be backed off and pootled along at 50-60mph. A couple of minutes and we are back to square one, foot down then feels like its being strangled again.
Any non-standard parts that might be involved with the problem?
Engine is a 1330, 3k since nut and bolt rebuild with aftermarket cam (not sure whether its a 266 or 276 off the top of my head), stg 2 head, roller rockers. Running aldon dizzy, vac sealed off (if that matters).
Car was rolling roaded last summer for this reason. All seemed good, however I dont think the tuner pushed the car long enough for the problem to arise. Not their fault I know! They changed the needle and plugs and altered the fueling. Car ran better on the way home but only had it on the motorway recently and problem still there.
This is my bro's car, not my own. Any ideas as to where the problem might be?
Posted 14 April 2009 - 10:25 PM
Posted 14 April 2009 - 10:27 PM
Posted 14 April 2009 - 10:31 PM
The vacuum being blanked off is what is bugging me, but I know nothing of aldon dizzys (electrixkery is beyond me anyway!)
Hence the plea for help. Secretly planning on stealing this car for riv run.
Posted 15 April 2009 - 12:12 AM
Posted 15 April 2009 - 12:50 AM
Posted 15 April 2009 - 08:17 AM
Posted 15 April 2009 - 10:40 AM
Posted 15 April 2009 - 10:46 AM
Edited by bert998, 15 April 2009 - 10:46 AM.
Posted 15 April 2009 - 12:19 PM
Posted 16 April 2009 - 12:18 AM
Ive been having a similar sounding problem. If im doing motorway driving at a constant speed of about 60, then I get a really bad flat spot and she doesnt want to go. I was told it was the carb icing up cause I have a pancake filter
Mine was head gasket blowing between middle two and exhaust gasket had had it too.
Posted 16 April 2009 - 07:13 AM
Carb icing was my thought when I read the first post as I had a the same symptoms on an Alfasud on a cold foggy day on the A1, but even on the coldest days I’ve never had a problem with the Mini which has a K&N cone filter.
In the Alfa I pulled over and took the top off the air filter and I could see the ice in the carb slowly melting. The warm air duct from the exhaust shroud had come off its mounting and the engine was drawing cold air from behind the front grill, I reattached the duct and everything was fine and dandy once again.
Posted 16 April 2009 - 10:48 AM
Posted 16 April 2009 - 11:30 AM
Posted 29 April 2009 - 10:45 PM
Just to add i took the mini out on sunday and the problem seemed to be replicated even when cruising about 65/70mph when going up any slight inclines, hadnt really noticed this before, just thought i'd mention it.
