ive recently changed the oil on Boris but im not 100% theres still enough oil in there?
Though hes driving much better its been suggested he may be low on oil as hes still slipping but only in one set of circumstances and thats going around sharp corners and roundabouts etc
Somebody suggested that there may not be enough oil in the engine/transmission?
Being my first Oil Change ever i figured if i measured what came out in dirty oil if i replaced it with the same amount in clean new oil i wouldnt overfill
Thing is i only got just shy of 4.5 litres out and the manual suggests just over 5 litres im scared of putting too much oil in but on the other hand if theres not enough?
How do you read the dipstick on the automatic?
Ive heard that you cant read it cold as you get a woefully inadequate reading,so i was told run the engine to warm the oil turn off and take a dipstick reading then?
If i do that it tends to show full but after whiping it it shows either full or min depending on how quickly i get the dipstick out whiped back in and out again :roll:
If anybody else has an auto when do you read your oil level and how much oil do you tend to get out and replace at an Oilchange?
If i have to top up after a dipstick reading at cold then i figure i still need half a litre , i just need to know the right way/time to take the reading will let me know if i need to top up or not?
Any advice you can give me will really help
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/smile.png)
Huggz
Jodie
