Front Wheel Sits Too Far Forward.
6 replies to this topic
#1 Dan6061
Dan6061
  • 761 posts
  • Local Club: -
Posted 18 April 2009 - 05:21 PM
My driver's side wheel sits too far forward, so when I am full lock the wheel scrubs the inside of the arch?
I've had a look at all the bushings, tie bars don't look bent to me, and the other side is fine, so the subframe alignment is alright!
Driver's side is like this: |---O-|
Passenger's side is like: |--O--|
If the tie bars are bent, would it be noticeable? I can get some pictures if you need them.
What else should I look at?
EDIT: After looking at pictures of tie bars on their own, they're perfectly straight. I think mine has a slight kink at the top. Would it be possible to straight it back? Or would it just weaken the metal and snap?
Might take them off and have a good look...
Edited by Dan6061, 18 April 2009 - 05:43 PM.
#2 lee&janmundy
lee&janmundy
  • 107 posts
Posted 18 April 2009 - 06:09 PM
let me know what you find out please mate
#3 jaydee
jaydee
  • 8,565 posts
Posted 18 April 2009 - 08:33 PM
Just an idea:
Have a look beetween front panel a subframe, where are the teardrop mounts. There are some shims in beetween..like this one:
http://www.minispare.....0BETWEEN FR...
They are meant to modify clearence of ur front wheel, probably you have a different ammount of spacers on one side so one wheel is closer to the front then the other one..
#4 MRA
MRA
  • 7,607 posts
Posted 18 April 2009 - 09:00 PM
Bent tiebars can be straightened, as long as they arn't seriously bent.... however for the price of a pair of new ones and a fixing kit and new rubbers...... its worth the extra expense than risking it
Although they would have to be very bent to cause the situation that you are asking about.... I would have to agree with Jaydee for the most part...... whilst measuring the lengths yourself you may discover that you don't have a matched pair... There are a couple of different lengths depending on your car.
#5 icklemini
icklemini
  • 2,982 posts
Posted 19 April 2009 - 10:53 PM
Are there??
standard tie rods are all the same length...
The front panel shims wont make a great deal of difference to your wheel clearance... the front panel is quite solidly welded on, and banging shims in there doesnt push the front panel forward by a huge amount. The shims are needed due to the manufacturing tolerancies and to line up the front subframe to the front panel..
#6 MRA
MRA
  • 7,607 posts
Posted 20 April 2009 - 08:13 AM
Are there??
Yes there are two differnt length of tie rod, may be not available anymore but they are there :P
#7 icklemini
icklemini
  • 2,982 posts
Posted 20 April 2009 - 11:21 PM
blimey - must have been long discontinued...
