Mini Cooper 1998
I'm trying to replace the tear shaped front subframe rubber bush, which has deteriorated and needs to be changed to pass the MOT. At first glance this looked like a straight forward job, undo a couple of nuts and put in the new bush, but I just can't get to the top nut to undo it and i think i must be doing something wrong.
I'm working in a pit so I'm trying to get to the nut from under the car, should I try accessing it from another angle?? do i need to remove something to get to the nut, do i need some specialist tools or is this a case of persistence and ET fingers???
Any suggestions much appreciated.
Hazel
Front Subframe Rubber Bush
Hazel McA
, Apr 20 2009 12:21 PM
6 replies to this topic
Posted 20 April 2009 - 12:21 PM
Posted 20 April 2009 - 01:06 PM
I guess you mean the top bolt? this goes into a captive nut into the fron panel. It is abit tricky to get too but i always remove the grille and attact it from the top
Posted 20 April 2009 - 04:36 PM
yes i mean the top bolt. I'll remove that front grill and give it a go. Thanks
h
h
Posted 20 April 2009 - 04:40 PM
i would replace it for a solid one
they always seem to go and you won't notice any move noise by going for a solid mount
Posted 20 April 2009 - 09:04 PM
If you replace the teardrops for solid mounts, invariably it puta too much stress and strain on the wings to scuttle and A panel area causing cracking
Posted 20 April 2009 - 09:18 PM
must take awhile though
mine have been on for 16 years with no cracking
Posted 21 April 2009 - 07:37 AM
It may be that you drive it a bit carefully then
Or you have an exception to the recognised rule...........
