hiya
is it possible to fit a 1100 crank to a 998 engine with 998 pistons??
i heard that the 1100 pistons need to be used??
would it be possible to machine the tops of the 998 pistons so that they fit???
cheers
adam
1100 Crank In A 998. Is It Possible To Use 998 Pistons?
stardude
, Apr 21 2009 10:19 AM
5 replies to this topic
Posted 21 April 2009 - 10:19 AM
Posted 21 April 2009 - 10:42 AM
you'd need to take of nearly 4mm to make them fit. My guess is that this will leave the distance from the top of the piston to the first ring too small.
Pistons are cheap, so why not just buy new ones?
Posted 21 April 2009 - 10:56 AM
I honestly think you'll find you have machined right through the crown if you do this. Or left the crown dangerously thin at least. As said above it's nearly 4mm that you'd have to remove.
Posted 21 April 2009 - 12:36 PM
ahh ok, i was just wondering. wont be doing that then lol
i did mean new pistons for the machining, as i will be getting +80 or +120 pistons for my new engine
many thanks
many thanks
Posted 21 April 2009 - 12:51 PM
you can get +60 1100 pistone here http://www.minisport.com.au/prod26.htm
Posted 21 April 2009 - 02:11 PM
what do think would give a better fast road engine??
+120 pistons with a lightly worked 998 crank
or
+60 pistons with a lightly worked 1100 crank??
the second option would give greater cylinder volume and torque would it not??
cheers
adam
or
cheers
adam
