Bypass Hose Keeps Exploding
9 replies to this topic
#1 w.murfitt
w.murfitt
  • 242 posts
  • Local Club: Flintshire Mini Owners Club
Posted 21 April 2009 - 08:51 PM
on my 1989 998 mayfair i'm on my third hose this year,
i've changed all the water hoses, water pump and flushed through the radiator and it just seems to keep blowing,
i cant find any blocks in the cooling system and am sure there is no air in there either any sujestions
i've used two for unipart and one from mini speed.
the mini speed one has lasted the longest so far bbut dont really want to have to keep changing them because its a pain in the bum.
cheers will
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 21 April 2009 - 09:00 PM
Well, you could just block it off.
Or reinforce your own bypass pipe with a touch of copper pipe.
#3 Nightrain
Nightrain
  • 976 posts
Posted 21 April 2009 - 09:02 PM
Have you checked the thermostat ?
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 April 2009 - 09:13 PM
are you using a good bit of rubber hose
#5 icklemini
icklemini
  • 2,982 posts
Posted 21 April 2009 - 09:14 PM
Use a piece of oil cooler hose (or power steering hose) - can withstand a hell of a pressure :thumbsup:
though that is solving the symptom and not the problem...
is the rad hot when it bursts? - are the stubs on the head and water pump clean? - using good clips? - *not* using the concertina type of hose?
#6 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 21 April 2009 - 09:17 PM
Silicone hose seems to be the best :thumbsup: .
#7 w.murfitt
w.murfitt
  • 242 posts
Posted 21 April 2009 - 09:27 PM
well i have a new thermostat and the most of the stuff is new i dont really want to block it off as that may make it worse if there is a problem... is power steering pipe the same diamiter?
and i am using jubilee clips.
#8 icklemini
icklemini
  • 2,982 posts
Posted 21 April 2009 - 09:29 PM
theres no reason why it should blow in preference to any other hose... unless the material is so crap it cant take 15lbs of pressure..
Could get the cooling system pressure tested to see if it blows...
comes in different sizes!
#9 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
http://www.minispare.....20BLUE SILI...
Silicone one!
#10 91neon
91neon
  • 447 posts
  • Local Club: abingdon owners club
Posted 21 April 2009 - 09:38 PM
i went against the grain and used a concertina. big mistake use silicon!!!!!!!!!!!!!!!!!!!!!!!
