4 Fuel Injectors On A Mini Engine
6 replies to this topic
#1 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 22 April 2009 - 09:59 PM
why dont people use 4 fuel injectors for the mini engine? i know there are 2 ports but the charge robbing problem wouldnt be a problem as far as i can see with 4.
could you modify a mems (mpi) loom to take 4 injectors becuse the join between the two injectors is on the loom, im really up for cutting it and making a mock up manifold with 4 to see what would happen, does anybody know for sure? or has anyone tryed this?
i dont see why you couldnt use any mappable ecu with 4 injectors, with 4 injectors you should get better fuel economy and power as the atomisation will be better
i really am wondering if the only reason that rover used two in each port was becuse it was cheaper and less of a squeeze.
any thoughs on this? i really am struggling to work out why so many people who inject the mini use 2 injectors not just rover.
#2 KLAS
KLAS
  • 107 posts
Posted 23 April 2009 - 09:11 AM
it can be done, and one guy over here is working on this.
but the charge robbing will be the same as this happens during the time both inlet valves are open. injecting only when only one valve is open will reduce this, you only have to cope with the differend volumetric efficiency of the cylinders.
using 2 injectors per port doesn't help as there will allways be a time no injector will inject, and than it makes no diference if you fire "injector1 - wait - injector2" or "injector1 - wait - injector1"
#3 redhotmini
redhotmini
  • 1,607 posts
Posted 23 April 2009 - 07:27 PM
i think part of the reason is having only 2 inlet ports. unless your running a 7 or 8 port crossflow style head then there isnt much benefit to be had running 4 injectors.
#4 SMP
SMP
  • 346 posts
Posted 24 April 2009 - 08:18 PM
Doesn't the canems system achieve almost the same effect as having four injectors but only using 2?
As you say Klas there is always a time when no injector is required to be open - therefore 1 injector per port is enough. However doesn't the canems do something to address charge robbing - such as injecting different amounts / times for each cylinder on one port?
Steve
#5 Dylan8660
Dylan8660
  • 206 posts
Posted 25 April 2009 - 10:59 AM
I'm building a manifold to take four injectors run from the standard ecu, hopefully I'll have some news either way in about a month.
I've always thought that the mpi would really suit the 7/8 port option, the only thing to work out and build would be the inlet and where to mount the alternator.
#6 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 25 April 2009 - 12:29 PM
have you thought about an alternator on the crankshaft? i thought you might be able to sqeeze it in by the pulley/ damper it would need to be low rpm PM alternator similar to motorbikes have or wind turbines, you could take the coils from a standard mini one and get some high grade neyodimium magnets to mount on the pulley,
#7 redhotmini
redhotmini
  • 1,607 posts
Posted 25 April 2009 - 12:35 PM
you could side mount the radiator, and put the alternator lower down as on carb'd engines. or even try and shift the rad to the other side so it sits in front of the clutch housing.
