Broken Door Lock - Barrel Has Come Out
6 replies to this topic
#1 Stevo33
Stevo33
    Starting My Mini Up
  • 2 posts
Posted 23 April 2009 - 04:23 PM
Hi all,
The barrel from the lock of the driver's door has come out with my key a few days ago. My local garage is telling me that I'd need to replace the lock, it is broken.
Now I amust admit I am not too familiar with replacing locks on a Mini...
Could you help me out with the following
Do you know what replacement parts I need by any chance? I can still lock the door from the inside and the "button" I press when opening the door works ok, it's just that the barrel is loose and I can't connect it anymore to the locking meachnism of the door handle.
Could you also roughly describe what I need to do?
It's an L reg Mini Sprite...
Many thanks, much appreciated!
Cheers,
Stevo
#2 Ethel
  • 26,027 posts
Posted 23 April 2009 - 04:43 PM
It's been ages since I touched on but I'm sure the barrel comes out to the key side and is just held in with a screw or star washer. Have a close look at where the barrel & where it fits to see if there's any wear, whether you need a complete handle will depend on what's worn. When you remove the key the levers should spring out and hold the barrel in anyway
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 23 April 2009 - 07:00 PM
You might just need to replace the star washer? So the barrel stays in place?
#4 leaky
leaky
  • 6,890 posts
Posted 23 April 2009 - 07:04 PM
My barrels come out quite a bit cant you just put it back in that what I do and as long as the key is in the barrel as I do it then it works fine.
Edited by Mini-jon, 23 April 2009 - 07:04 PM.
#5 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 23 April 2009 - 07:14 PM
Just take the door panel off and knock the star washer tighter in place.
Also lubricate the lock mechanism so the key doesn't catch and pull the barrel out.
#6 Stevo33
Stevo33
    Starting My Mini Up
  • 2 posts
Posted 23 April 2009 - 08:01 PM
Thanks for the replies, I will have a look on the weekend!! :)
#7 leaky
leaky
  • 6,890 posts
Posted 24 April 2009 - 02:16 PM
Thanks for that I'll do that this weekend.
