how much is it for a decent respray these days?? keeping my original colour black - but car is 20 years old now and needs a touch up
Posted 27 April 2009 - 12:06 PM
Posted 27 April 2009 - 12:18 PM
Posted 27 April 2009 - 12:24 PM
Posted 27 April 2009 - 12:31 PM
Defo buy a heritage panel. The fit of my non heritage one is pants. so im simply not going to put it back on.
Posted 27 April 2009 - 01:23 PM
Posted 27 April 2009 - 02:16 PM
Posted 27 April 2009 - 02:28 PM
how hard is it to replace the front one, mines all bent and after messing up the holes for my spotlights a new one would be a good idea
Edited by brianmini, 27 April 2009 - 02:31 PM.
Posted 08 May 2009 - 11:45 AM
Posted 08 May 2009 - 11:54 AM
ouch I think I'll leave it for nowhow hard is it to replace the front one, mines all bent and after messing up the holes for my spotlights a new one would be a good idea
Quite a lot when it comes to the front panel. You need to cut (angle grind) below the lights (seperating wing from front panel), then all the associated grinding back to get the wings back into original shape. You also need to seperate the front panel from the inner wings, they're connected in 2 places, I hacked the front panel off and then addressed the area's where they joined the inner wing. And you need to unbolt the front panel from the subframe.
Then you need to bolt the new panel onto the subframe, line it all up, clamp it up and spot/plug weld the front panel lip to the inside of the wings, and the 2 tabs each side which mount into the inner wings. Lots of work, I only did it because 80% of my front panel was rust.
I'd say too big a job just for a few dents, but if the panel is disolving then its worth it.
Posted 08 May 2009 - 12:21 PM
How bad does the rear valance have to be before the MOT man will fail it? as mine is rather mis-shapen after dropping it on the jack and has a thumb sized rust hole just below the fog light mounting.
Posted 08 May 2009 - 05:53 PM
My rear valance was a state and it kept passing its mot. If its just the one hole you can grind it back and patch it and skim it (if its small enough just skim it). If the valance is frilly in a number of places though then you'd be as well to replace the entire thing. But as above, its not the valance that'll be the issue when you replace, but the closing panels and boot floor when you get the valance off.
