Fitting Carpet
7 replies to this topic
#1 dsgoody
dsgoody
  • 519 posts
  • Local Club: Gert Lush Minis
Posted 27 April 2009 - 04:25 PM
Hello all,
Need to fit my new carpet this coming weekend and not 100% sure on how to go about it. I have found this post here to be helpful but does not cure my problem. Can anyone tell me where the points are where the carpet clips rivet down because either my car does not have them (it's a early 1990 Racing Green) or I'm not looking hard enough. Also, does the heater need dropping out a tad to get the bulkhead carpet in?
If anyone could help me it would be a great help, Dave.
#2 dsgoody
dsgoody
  • 519 posts
Posted 28 April 2009 - 02:17 PM
Anyone? Someone must know.
#3 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 28 April 2009 - 11:42 PM
I didn't take my carpet out for my carpet but it's quite tricky, I used spray glue but it only lasted around 3 months then all fell off. I have now used no more nails double sided tape and it seems to have done the trick, will have to see how ling it lasts though.
#4 dsgoody
dsgoody
  • 519 posts
Posted 30 April 2009 - 08:57 AM
Thanks for the tip. Did you not use the carpet clip set the Minispares sell then?
#5 roberts
roberts
    Optimise Automotive
  • 3,295 posts
Posted 30 April 2009 - 09:31 AM
what carpet set have you bought??
I didn't use clips, the pieces are all shaped, or so I thought they where??
They basically sit in place without any hassle, simply take your seats out, remove your seat brackets, if you have a centre console/kick board etc. remove those, then rip out your old carpets and put your new ones in.
The only bits I glued was the cross beam section on the floor, which is a must, and then the inner arches, which didn't need doing because they have metal thingies to hold it on, but I did it anyway.
It's a future product of mine so glad you have said this!! Whats this about rivets and clips to hold carpet in??
#6 dsgoody
dsgoody
  • 519 posts
Posted 30 April 2009 - 09:46 AM
Well, Minispares sell a set here that's supposed to hold your carpet in place. Brought it because it was only £3 odd and stumbled across this post here. Apparently these clips rivet down to specific raised points on the floorpan to hold it all in place, but I can't find these points. If nobody knows then I will just glue it all in place.
The carpet set itself is only a cheap one from MiniTrimmings. Brought it because I liked the material is was made out of.
Edited by dsgoody, 30 April 2009 - 09:47 AM.
#7 roberts
roberts
    Optimise Automotive
  • 3,295 posts
Posted 30 April 2009 - 10:08 AM
mm my standard rover original carpets didn't have those clips like Mini Spares claim... its a 96 Mini, so perhaps its only the late Coopers that had them?
My experience says you wont need any fixings or glue for the big floor carpets there well shaped and simply sit in place without moving.
#8 dsgoody
dsgoody
  • 519 posts
Posted 30 April 2009 - 10:23 AM
Ok. Well I will see how I get on this weekend with fitting it. Thanks for the help.
