Inner Wings (flitch Panels) Repairs
7 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 28 April 2009 - 02:48 PM
Hi
On my 1960 mini, I need to replace the front end panels (front panel, wings, a-panels, and the inner wing (flitch) as far back as the shock mounts.
I have herititage panels which I will use, but need advice on how to weld the front repair sections of the inner wings (flitch) to the rear part of it. I know that a butt weld will make an invisible repair, but is this the usual way to weld it, or is joggling the best way with a full seam weld?
The repair section will be from the very front to the shock mount holes, which i can use to help align the panel.
Also, generally is the front end an easy and quick replace in general?
Any help and advice would be great
#2 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 28 April 2009 - 02:59 PM
You never want to joggle a weld, it looks horrible and just causes rust.
Front ends are very easy. Bolt the front panel to the subframe, make sure the bonnet closes nicely to it then fit the wings to suit the bonnet. Do the A panels last.
Paul
#3 widerim_pickup
widerim_pickup
  • 661 posts
  • Local Club: nope
Posted 28 April 2009 - 06:24 PM
I would do a butt weld join, joddled panels look pants and tend to rust from the inside out as paul said.
#4 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 29 April 2009 - 11:20 AM
Classic case of more preperation, better result.
#5 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 29 April 2009 - 06:55 PM
I do them something like this..
Attached File  scrippo3.JPG   1.18MB   114 downloads
Attached File  scrippo4.JPG   1.25MB   94 downloads
Attached File  scrippo5.JPG   1.26MB   100 downloads
#6 Give it a bash
Give it a bash
  • 32 posts
Posted 18 May 2009 - 10:00 PM
Hi there. I've just read your reply to replacing part of a flitch pannel, nice work. do you know how you go about replacing the lot? Mine was bent all the way to the dash when i bought the car and have already gone mad with the angle grinder. Cannot for the life of me work out how you get right into the top.
Cheers.
#7 jjojjas
jjojjas
  • 272 posts
Posted 20 May 2009 - 07:16 AM
Cheers.
you get right into the top by removing the scuttle. Its sandwiched up there between the scuttle, the inner wing/fitch and the inner dash. Where the widscreen rubber fits over it.
here. The scuttle and closing plate are removed.
Jas
#8 Give it a bash
Give it a bash
  • 32 posts
Posted 21 May 2009 - 05:41 PM
Cheers.
Jas
Many thanks for the reply. They don't like to make life easy do they. Oh well back to the grinder.
Thanks again
Rick
