Can't Undo Hub Nut
Posted 29 April 2009 - 12:39 PM
I can't find anything to put over my small breaker bar, I tried looking for a scafold bar but can't find anything.
Any suggestions?
Posted 29 April 2009 - 12:52 PM
i know it sounds bodge job, but if your desperate...
Posted 29 April 2009 - 12:54 PM
bit of strong wood taped/cable tied?
Hmmmm, could work but would have to be a stupid amount of zip ties, and I realy don't think tape is going to cut it.
Posted 29 April 2009 - 01:20 PM
Posted 29 April 2009 - 01:26 PM
I'm afraid you may need a good metre long bar to get the thing undone, they're not that expensive really, maybe buy one? I presume you have the correct socket?
Also, have you a torque wrench suitable for tightening the nut again when you put it back on, just going for FT isn't enough.
Dave
Posted 29 April 2009 - 01:30 PM
Posted 29 April 2009 - 01:31 PM
Borrow a bigger breaker bar, from the uni if needed.
Dave
Yeah Ive got my torqure wrench available but it clicks when using it to undo it, Im just going to have to bite the bullit and buy a big ol breaker bar, my uni doesn't have and kind of engineering/mechanics courses so can't borrow anything from them.
Oh and ive snapped a stud before but the studs come out of the back of the drive flange onto the disc so I can't tap them out, ive tried that already.
Ben
Posted 29 April 2009 - 02:23 PM
Just so you know, you should NOT try to use a torque wrench to undo tight bolts, at least you stopped when it clicked, but it can damage the mechanism. Better buy a big breaker bar, one of the best things I ever got, you'd be amazed how often you use it...Yeah Ive got my torqure wrench available but it clicks when using it to undo it, Im just going to have to bite the bullit and buy a big ol breaker bar, my uni doesn't have and kind of engineering/mechanics courses so can't borrow anything from them.
Ben
Dave
Posted 29 April 2009 - 02:47 PM
I agree about it not being possible to knock out a standard stud when its broken, it fouls on the hub. But once you've got the hub nut off its easy enough to replace the studs.
Posted 29 April 2009 - 04:42 PM
Posted 29 April 2009 - 05:30 PM
Had a similar problem on a previous car I used a length of scaffold tube placed over the breaker bar.
my dad tried that on one of his cars's.
he bent the scafolding pole!
Edited by Burnard, 29 April 2009 - 05:30 PM.
Posted 29 April 2009 - 06:20 PM
Thats what I usualy use.
I bought a breaker bar but the biggest i could get was not the best 600mm, I got the breaker bar on and used a trolley jack to lift the bar. The only real issue after that was getting the broken studs out, so had to go out again and buy a hammer.
All done now, but the bolts that go disc-drive flange have damaged threads in the disc so I have to buy new discs now, ah well.
Posted 29 April 2009 - 07:20 PM
I just cant undo the nuts on the drive flange
Posted 30 April 2009 - 06:34 AM
Ben
[/quote]
Using your torque wrench to undo has completely screwed up any calibration it may have had
