Weather Shields/ Splash Guards
11 replies to this topic
#1 Laaly_30
Laaly_30
    Previously know as sbsbemey
  • 269 posts
Posted 29 April 2009 - 01:27 PM
i was wondering how the above works, and how they go in the engine bay as im looking to get one but would like to know more on them first please, so any info anyone has or pics of how they fit in etc would be great :D thanks!
#2 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 29 April 2009 - 01:30 PM
They stop the distributor getting wet when its raining! Theres 3 brackets that its held on by and it just fits infront of the engine :) There a good idea, but I tend to use a rubber glove over the dizzy instead!
I dont have any pics though im afraid :D
#3 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 29 April 2009 - 01:39 PM
Attaches to two brackets on the rocker cover. Mine is just held with cable ties.
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 29 April 2009 - 08:23 PM
This seems to be the cheapest place to get them, even though Mini Spares have lowered their prices a bit to compete (but not enough though): -
http://www.minispare...h...ld&s=Search
#5 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 29 April 2009 - 08:48 PM
Theres nothing exciting about them, they prevent water having direct contact with your electrics.
They use the top two rocker bolts, there is a third fastener but its right at the bottom near the gearbox, alot of people dont use this one as its a PITA to get to, the lower part of the shield will slide in nicely between the bodywork and grill or thereabouts so its really not needed.
Heres mine, always best in clear unless your engines a bit on a mucky side!
:crazy:
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 29 April 2009 - 09:15 PM
Clean, dry and well serviced electrics are the best way forward on Minis.
Just try not to use WD40 unless you really have to and then be sure to clean it all off otherwise it'll attract muck and grime and you'll have even bigger problems, then.
Plus it stinks on a hot engine.
#7 Laaly_30
Laaly_30
  • 269 posts
Posted 29 April 2009 - 09:34 PM
thanks :P i ordered a one from mini spares. Then just to fit the bugger! hopefully ill not be having to nurse the mini home in the rain in future =[ now just the stressful bit of fitting hehe
#8 wilcooper
wilcooper
  • 1,197 posts
Posted 29 April 2009 - 09:49 PM
i've just got a square of plastic ziptied to the grille in front of the dizzy.
#9 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 30 April 2009 - 08:55 AM
Was thinking about getting one of those, but then realised that because of the aircon compressor, the alternator sits much higher so the shield will not fit... :P
#10 Juju
Juju
  • 3,620 posts
Posted 30 April 2009 - 09:17 AM
Shame they don't make these for water ingress from beneath. :P It's not the rain itself that scuppers Matilda, it's the puddles & standin water.
#11 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 01 May 2009 - 09:44 PM
Was thinking about getting one of those, but then realised that because of the aircon compressor, the alternator sits much higher so the shield will not fit... :xxx:
Well you could fit the pre-1987 type as fitted to round fronted Minis. That was just a piece of moulded plastic that was screwed on to the back of the front panel, so it protected the distributor.
I owned 2 older Minis with that type of weather shield and it seemed to work just as well as the later larger version that used the mountain brackets instead.
I'm sure you could get one from Somerford Minis?
#12 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 01 May 2009 - 10:57 PM
Thanks for that, Taffy... :xxx: I now use a plastic dizzy cover for Mercs that wrap around the dizzy. Works just as well... :)
