I guess what your mate is going to do is hand scrape the block ?? or worse !!! what ever he is planning on doing will result in total eventual wastage of your hard earned cash.......
Grinding material WILL get in to your engine it WILL destroy it, no matter how careful he is some element of swarf or cutting compound etc WILL enter the WRONG places
ferrous metals around your piston rings will glow red and pre-ignite and could lead to severe piston damage
DO NOT LET HIM TOUCH YOUR ENGINE
To strip your engine down for skimming will cost you time, a set of gaskets, descent head gasket (BK450), oil, filter, thread lock and any bits that are damaged.
Ok if this is a new engine why is the block not flat ?
how are you checking that the block is flat ?
What tools are you using to "diagnose" a warped block ?
warped "A" series blocks are not that common !
If it is warped then it will have to be done on a machine, either a mill, or for preference a vertical spindle surface grinder
Ask him what he intends to do .... exactly ??
