Simple Speedo Cable Problem!
5 replies to this topic
#1 chizzle
chizzle
  • 23 posts
  • Local Club: not at the moment.
Posted 02 May 2009 - 05:11 PM
hi,
right iv recently bought a 1986 city e 998cc and the previous owner changed the standard dials with what he told me were 1275 gt ones. the problem is he didnt have time to fit the cable before the sale, so its currently attached at the dial side but not in the engine bay.
my question is where do i attach the cable and ultimately will the dials work on a 998cc having perviously been on a 1275gt.
as you can probably tell i have know idea what im talking about! so pretend you're talking to an idiot haha
any pictures would be great!
cheers
guys
#2 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 02 May 2009 - 06:32 PM
speedo cable should be the same and attaches to the back of the gearbox casing on the right handside to the best of my knowledge ill go out later and have a look where its connected and send u a pix
#3 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 02 May 2009 - 06:59 PM
I bet he didn't have time!!!!
Its an awkward fiddly little job to so and I bet he didn't want to do it!!!
The threaded bit on the engine where the cable attaches to is on the radiator side of the engine, jack the car up and look from underneath and you should be able to see where it attaches to.
You may be able to screw it on from underneath, however if you can't then it may be easier to remove the rad and get at it from the top.
If you don't already have one, get a haynes manual, will make life a shed load easier
#4 chizzle
chizzle
  • 23 posts
Posted 02 May 2009 - 08:00 PM
thanks very much for the quick replies! very helpful comments!
il have a look tomorrow as its dark now but if (Saxo-Fiesta-Mini) you could send me a pic that would be seriously helpful!
cheers
#5 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 02 May 2009 - 10:41 PM
Its still gonna be dark down there when you have a look in the morning, not easy to spot! :thumbsup: Make sure you got a powerful torch!
Heres the location
Bear with me on this, I dont know how much you know so I'm just covering all areas? ^_^
Make sure you locate the speedo cable first as I'm assuming its dangling around the engine somewhere???? If you cant find it grab it from behind the dash and pull it inwards, you may need to disconnect it from the back of the cluster if you do have trouble pulling it in as its not that flexible.
If you cant get it disconnected at the cluster end try this link Clicky
If your lucky the last owner has at least left it near where it goes, so should be visible from underneath, get it jacked up high enough on axle stands to give yourself enough clearance - use axles dont rely on the jack alone :shy:
If your still struggling your gonna have to take the radiator and fan off as said above, be a good time to flush the radiator and clean it out anyway!
#6 chizzle
chizzle
  • 23 posts
Posted 03 May 2009 - 07:30 AM
WOW! thats hugely helpful!!!
yeah iv found the cable and im pretty sure its on the correct side so all there is left to do if find that bloody hole haha
again many thanks to all that posted!
Edited by chizzle, 03 May 2009 - 07:33 AM.
