Help With Hi Los, Hampshire!
9 replies to this topic
#1 smoggy_clubman
smoggy_clubman
  • 239 posts
  • Local Club: not yet!
Posted 02 May 2009 - 08:15 PM
Hi just got my mini clubman but the hi los are set up all wrong was wondering if anyone near gu35 fancys earning a couple of beers and doing me a big favour?
Ste
#2 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 03 May 2009 - 06:45 AM
what do you mean by "all wrong".
simple adjustments of the ride height are very easy to do, you just need two spanners, a short rule and the ability to jack the car up and remove a wheel :shy:
whats the short rule for? well the best way to get the height the same on both sides is to measure the area of exposed thread :thumbsup: well its a good starting point
#3 Brown Mini
Brown Mini
  • 98 posts
Posted 03 May 2009 - 08:47 AM
Hi
I'm in GU52 if you want to borrow the right size spanners etc
As the last post said, it's pretty easy
Andy
#4 smoggy_clubman
smoggy_clubman
  • 239 posts
Posted 03 May 2009 - 09:12 AM
Hi
Andy
see the guy i got it of tried to sort it and he had a long spindal type tool?? as i dont have one i guessed i couldnt do it without! Is there a how to anywhere and ill just crack on! what size spanners are they?
#5 nicksuth
nicksuth
  • 1,631 posts
Posted 03 May 2009 - 09:27 AM
Hi
Andy
I think if they are the older type HiLo's jou will need a long hexagon bar (Allen Key) to adjust them???
http://www.minispare...=...&title=HILO HEXAGONAL ADJUSTING ...
Edited by nicksuth, 03 May 2009 - 09:28 AM.
#6 smoggy_clubman
smoggy_clubman
  • 239 posts
Posted 03 May 2009 - 01:36 PM
Hi
Andy
it wasnt quite like that it was like a long box spanner with a threaded bar running through it, there was a handle shaped bar on that and a handle right at the top?
#7 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 03 May 2009 - 03:11 PM
are you talking about a cone compression tool ? was he using it under the bonnet ???
#8 smoggy_clubman
smoggy_clubman
  • 239 posts
Posted 03 May 2009 - 03:32 PM
yep thats the badger! sorry ive got alot to learn about minis!!
#9 smoggy_clubman
smoggy_clubman
  • 239 posts
Posted 03 May 2009 - 03:51 PM
could this just be worn cones? its rubbin like mad front right, front left catches on hard turns and the rear left looks high compared to the other??
#10 smoggy_clubman
smoggy_clubman
  • 239 posts
Posted 04 May 2009 - 02:09 PM
Is there a "how to" anywhere on hi los as when i search it says i need bigger words?? lol
