Recommended Engine Rebuilders In North West?
Cater_Racer
, May 03 2009 07:32 AM
6 replies to this topic
Posted 03 May 2009 - 07:32 AM
I've had bad experiance with engine builders, last year I bough a "New" Engine and gearbox, but it uses oil almost as fast as it does petrol, and and the hot oil pressure is not enough to keep the oil pressure warning lamp off. The gearbox seems ok, but I fear that I will need to get the job done properly. Can anyone recommend someone who really can rebuild a mini engine?
I live near Chester.
Model:998 cooper
Year:1964
Description of problem (please be as in depth as possible):Low oil pressure and excessive oil consumption
Any non-standard parts that might be involved with the problem? 276 Cam & duplex timing chain
Model:998 cooper
Year:1964
Posted 03 May 2009 - 07:47 AM
Did you get this engine on a rolling road ?
Posted 03 May 2009 - 08:17 AM
Yes, I was advised to put it on a rolling road by the installers, I took it to Hereford and the it was there that I noticed the blue smoke, by the time I returned home I needed a litre of oil!!
I saw 55 BHP on the dyno.
Posted 03 May 2009 - 08:54 AM
is birkenhead to far for you ?
Posted 03 May 2009 - 08:57 AM
Birkenhead is just around the corner for me! I was thinking of trailering to Pert (Scotland not Australia)is birkenhead to far for you ?
Posted 03 May 2009 - 09:42 AM
speak to tony or jamie at merseyside engines 0151 649 0009.
tony's been doing engine re builds etc for twenty odd years so he knows what he's talking about.
tell him carl gave you his number
Posted 03 May 2009 - 10:10 AM
Will do thanks Anon
