Running In...
Posted 03 May 2009 - 08:50 AM
What are the general rules for 'running in' a rebuilt engine that has new pistons ?
Max speed?
Max RPM?
For how many miles before oil change?
Posted 03 May 2009 - 08:52 AM
Posted 03 May 2009 - 10:03 AM
EDIT: Just checked out the above link... thats where i read about driving it hard
Edited by monkey, 03 May 2009 - 10:06 AM.
Posted 03 May 2009 - 12:52 PM
Think I'll just drive it easy with an occasional blast
I've got straight cut drop gears so even taking it easy sounds like I'm canning it !!
Posted 03 May 2009 - 01:02 PM
Take it easy (no more then 3000 revs) gradually building up the revs for upto 1000 miles (yes one thousand)
Have you had a new camshaft, you must start it and run it at about 3000 revs for about 30 minutes NOT under any load..... any issues switch it off straight away rectify and carry on..
150 miles will just waste your time and money..... this is what main agents tell you as most engines are run up on a test line for a certain period before even getting in to a new car, also they want to be able to sell you another car in so many years because your engine has failed....
I had a main agent telling me not so long ago to bed in the brakes by stamping on them hard from 50mph to a dead stop ASAP do this a couple of times he said and my brakes would be bedded in !!! needless to say they won't be getting any work off me in future.
Posted 03 May 2009 - 03:55 PM
Yes i did the 3000 rpm from start up for 30 mins
I've tried to keep under 3500rpm so i'm close.... it's so hard !! - have done a whole 165 miles !!!
Was hoping to get it run in before london to brighton
Posted 03 May 2009 - 03:59 PM
I was took the take it steady advice. But I was passed a link from an engine builder to a guide, which basically said after inital starting, oil pressure checks and bedding in the cam, you need to drive it hard in the first couple hundred miles and get the engine under load to bed things in properly.
Everyone as a different opinion on it. Ive just drove my last few like normal, i don't red-line engines or anything anyway.
Posted 03 May 2009 - 04:51 PM
Posted 03 May 2009 - 05:01 PM
Talked to my dad about this before. He basically said run it to about 800 miles not revving the nuts off it and not [putting the engine under load (i.e. 30 mph in 4th gear). Then afterwards, you can use it 'properly'
Yes but don't take it "easy" for 800 miles and then cane it relentlessly....
Build up gradually.... start at 3000 revs if you have an 800 mile limit and a redline of 7000 thats 500 rpm increase for every 100 miles..... which means that you should be able to take it to 3825 max
I suspect that Jordies engine builder friend does more diesels than petrol, in which case the pistons and rings are of a completely different material which does need to be under load to work and bed in fully..........
Edited by mra-minis.co.uk, 03 May 2009 - 05:04 PM.
Posted 03 May 2009 - 05:05 PM
I didn't mean redline it straight away from 800 miles onwards. Just that you can start revving it after 800 miles.
Posted 03 May 2009 - 05:07 PM
Posted 03 May 2009 - 05:14 PM
Paul
Edited by Paul Wiginton, 03 May 2009 - 05:15 PM.
Posted 03 May 2009 - 06:34 PM
A lot of engines for race cars last how long ? 1 or 2 seasons, I would agree with the dyno report, simply because by "nailing" it you are bedding it in quicker or more to the point wearing it out with a massive dose of bore wear.
This has the effect of polishing the bores, which over a long period of time would also polish the rings, however at this accelerated rate the rings do NOT bed in, but the friction value is decreased and therefore more power..... which for a race engine not doing a great deal of miles is fine.
After a 1000 or so miles a well bedded in engine will "loosen up" and generate more power, as the bores and rings are seating in and working together correctly.... this then gices you a better longer lasting road going engine
