Rear Wheel Bearing
Posted 05 May 2009 - 01:46 PM
Tom
Posted 05 May 2009 - 03:13 PM
See attached extract from Haynes.
Well I would upload it but it appears I can no longer upload and also appear to now be a non member!!!!!
PM me your email and I'll send it as an attachment if you don't have a Haynes???
OOOPPSS - now I've renewed my expired membership I can post again!!!
[attachment=84653:Rear_Whe...Bearings.pdf]
Edited by nicksuth, 05 May 2009 - 03:21 PM.
Posted 05 May 2009 - 04:14 PM
Posted 05 May 2009 - 06:27 PM
Posted 05 May 2009 - 06:44 PM
If the Bearing Kit is bought from a reputable dealer then the bearings and spacer should be supplied as a "matched" set with reference numbers marked on each item to denote "set".
odd, as I purchased them from DSN - no matching numbers though!
Posted 05 May 2009 - 07:06 PM
Posted 05 May 2009 - 08:08 PM
Posted 05 May 2009 - 08:22 PM
If there is no spacer in the kit then both bearings should have the spacers built in, make sure you put these facing each other. If this is all correct you shouldn't get any concerns. I have fitted several taper roller kits to the back of my mini's & fingure crossed never had any problems. Have you checked the radius arm to check that the inner of the old bearing isn't stuck on the shaft. sometimes they will stick & the ball bearings & carrier will come away without it.There was no spacer in the set that i bought, though it looks like one is 'built in' to the inner part of the bearing. is it possible to get the original ball bearing types anymore?
Posted 05 May 2009 - 08:28 PM
I had exactly the same problem with a set of bearings bought from DSN. So I bought a set of genuine Rover bearings and had exactly the same problem. I spoke to Steve at DSN who was very helpful. In the end I fitted a shim between the two bearings which allowed the hub nut to be torqued up to the correct figure and the bearing still free to let the hub turn.
where did u get the shim?
Posted 05 May 2009 - 08:34 PM
Did DSN supply the shim?
Posted 05 May 2009 - 09:01 PM
Rear tapered roller wheel bearing kit, for one wheel. All post 1985 cars and the Mini Cooper S were equipped with very heavy duty tapered roller wheel bearings; these can be used on any Mini. Kit includes inner and outer bearings with spacer plus seals. If you are into preventative maintenance, then the tapered bearings are much easier to remove and re-pack than the ball bearing type. Stronger design, plus easy maintenance means they will last longer than the rest of the car. These are the later type with an improved bearing for use on larger wheels with a better O ring sealing qualitiy, introduced by Rover as a warranty buletin upgrade on minis with 13" wheels. O RING GOES BETWEEN FIRST BEARING AND BACKPLATE ON STUB AXLE-radius arms have a recess for the seal
I Assume the cheaper set are non-original and the others are Timken and Rover???
Somerford's Parts List/Diagram added for reference.........
[attachment=84681:07_RearS...bberCone.pdf]
Edited by nicksuth, 05 May 2009 - 09:09 PM.
Posted 06 May 2009 - 10:18 AM
Just checked MiniSpares website and they offer 3 x Taper Roller Bearing Kits, all of which refer to the kit including a "Spacer".
i read that same product description but its not totally clear whether the spacer is part of the bearing or a completley seperate part.
Posted 06 May 2009 - 09:54 PM
Posted 06 May 2009 - 09:56 PM
http://www.minisport...fo_GHK1548.html
Posted 07 May 2009 - 01:56 PM
Tom
