Front Drum Break Cylinder Problem
8 replies to this topic
#1 Joethemojomower
Joethemojomower
  • 100 posts
  • Local Club: no
Posted 05 May 2009 - 04:56 PM
I have a Mini HL and my front pasenger side break cylinder has a leak (the one on the right)
It covered my front drum break in break fluid, which acted as a lubricant, so my left side doesnt break, so when i break i turn right (onto incoming traffic)
Not fun!!!
I have had a look and i need to replace the Rubber seals.
Can i replace the seals without taking the Break cylinder of?
and if i take of the cylinder, i might aswell put a nice shiney one on there, for only a couple of quid more.
Whats the best thing to do?
Edited by Joethemojomower, 05 May 2009 - 04:58 PM.
#2 Zacherius
Zacherius
  • 525 posts
  • Local Club: M4MINIS
Posted 05 May 2009 - 05:25 PM
Not fun!!!
I bought New cylinders for mine ( 1981 HL Auto with drums all around ) for under £3 each Brand New from Welsh Autoparts (welshautoparts.co.uk ). So at that price, its better to be safe than sorry, especially with brakes !
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 05 May 2009 - 05:46 PM
Going with it's a daily driver, so you want the part now. ~Try local parts shops. Cost will be around £10 for a new cylinder. £2 for another bottle of fluid.
#4 Joethemojomower
Joethemojomower
  • 100 posts
  • Local Club: no
Posted 05 May 2009 - 08:11 PM
i have tried a shop near me, and they said they may have one knocking arround somewhere. and to pop in on saturday.
I will go for new cylinders, deffianatly be safe than sorry with Breaks.
its nearly a daily driver, I am only a Learner at the moment.
want to get it fixed asap. because my otehr cars a Ford Ka
Oh dear eh?!
#5 minisandfords
minisandfords
  • 138 posts
Posted 05 May 2009 - 08:24 PM
Definitely replace the cylinder- if you replace all 4, particularly with new drums and shoes adjusted up right, you will notice a huge difference.
Just done this to mine; replaced the lot and brakes like a different car. Just make sure you put the drum return springs back on right, and give the system a good bleed once you have done!
#6 MRA
MRA
  • 7,607 posts
Posted 06 May 2009 - 12:06 PM
Hi,
The front has 2 per side, which ones leaking ? or are both leaking ? also you will need a new set of shoes, brake fluid will ruin the frictional qualities of the shoes it has soaked in to.......
At £3 each they are not going to very high quality....
I Use either QH or Delphi which are made in the EU.
A quality wheel cylinder will have a better surface finish in the bore of the casing part, cheaper ones are quite rough and hence seals do not last that long :D
Regards Martin
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 06 May 2009 - 12:52 PM
Oh dear eh?!
If you can't get any by this afternoon, send me a PM I can check my local shop in the morning and post you some. Well, for the cost of postage and parts.
#8 Joethemojomower
Joethemojomower
  • 100 posts
  • Local Club: no
Posted 07 May 2009 - 09:54 PM
cheers you have all been a really great help
What i think i will do is pop along to the spares place near me, they said they may have some cylinders knocking arround, But i am just about to invest in some Superfins, and new shoes. And shall pick up some new break fluid as well.
Yayy, no more pulling to the right into oncoming traffic :gimme:
#9 Zacherius
Zacherius
  • 525 posts
Posted 08 May 2009 - 07:03 AM
ooooh. Now you tell me :thumbsup:
May have been £3 but i've bought so much stuff from these guys over many years and never had a prob. They actually sell to most of the motor factors and shops in Cardiff, so are just really cheap ( usually ) in comparison to going to elsewhere. ( For example, the box they came in, is the same as the box (manufacturer) that two other shops in cardiff were going to sell me, yet for £8.98 and £9.95 )
(For another example, I bought a Fan Belt for £2.26 from them )
Just one of those good old shops that no-one usually goes to except trade.
