Cracking An Egg Into Leaky Radiators?
13 replies to this topic
#1 MrMini
MrMini
  • 531 posts
Posted 05 May 2009 - 05:15 PM
Well its an old myth that cracking an egg into a leaky radiator seals the leaky hole(s), now i think that i tried this about 4 years ago and had very sucssesful results, but then again i may have dreamt it as my memory is not that great! :D
So as this myth has never been tested by the 'mythbusters' i am asking you lot, does it actually work?
Discuss. >_<
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 05 May 2009 - 05:17 PM
heard of it before, but never done it. Radweld or Barr's radiator leak stuff normally is my course of action.
#3 Zacherius
Zacherius
  • 525 posts
  • Local Club: M4MINIS
Posted 05 May 2009 - 05:18 PM
Wasn't it just one of those tricks used by dodgy used car salesmen as a temporary measure to stop the leak long enough to get someone to buy the car ?
Just like sawdust in the oil to stop Head Gasket Leaks !
Wouldn't the egg just boil, go off, then start stinking ?
#4 lukemull
lukemull
  • 58 posts
Posted 05 May 2009 - 05:34 PM
yea i tried it about 2 months ago.
haven't had a prob since lol
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 May 2009 - 05:35 PM
i thought it was just the egg white you put in
#6 johnbest981
johnbest981
  • 269 posts
Posted 05 May 2009 - 06:32 PM
i know it worked on my brothers Honda Integra as a temporary fix until he got a new radiator, but i couldn't tell you if it was the complete egg, or just the white. but i know it worked for about 3 weeks until he got it properly fixed.
#7 racingbrett
racingbrett
  • 18 posts
Posted 05 May 2009 - 06:44 PM
eggs works but not always the gooey clear stuff basically boils then gets forced into the leak, all depends on the size of the leak,,, just a note of caution with bars leaks and red weld (maybe even egg) carefull what car u use it in, while it may be ok in older cars be real care full using it in more modern motors, i had to use it a few months back on my jeep, instead of just 145 notes for a new rad its turned into a new water pump, stat, new lpg vaporiser loads of flushing and a few small pieces of pipe, an extra 200 notes add to that weeks of hassle and looking for blockages, many newer cars have the pipe work go down to smaller bores in some places this spells trouble, rad weld and bars leaks managed to jam up my whole cooling system.
#8 MRA
MRA
  • 7,607 posts
Posted 06 May 2009 - 11:35 AM
Yep that's what they do... it's their job to block up holes and pretty good at it they are too :D unfortunately it's not always the holes that you want blocking that get blocked up..... :D
Regards Martin
#9 jaydee
jaydee
  • 8,565 posts
Posted 06 May 2009 - 11:50 AM
Yes it is
#10 TooFPaste39
TooFPaste39
  • 83 posts
Watch Mythbusters...it was proven that it does seal up the holes. But only for a certain amount of time.
#11 MrMini
MrMini
  • 531 posts
Posted 06 May 2009 - 08:37 PM
So if you were to do this temporary fix you should go for just a single egg white rather than a whole egg?
#12 MRA
MRA
  • 7,607 posts
Posted 06 May 2009 - 11:52 PM
Yes just use the white of the egg........... especially in light of the fact that the whole just will not fit through the hole in the top of the radiator :thumbsup:
also take note of issues other people of had above..... A new or good second hand radiator could prevent further issues later on down the line ;)
#13 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 06 May 2009 - 11:58 PM
Always cary a small bottle of rad seal, probably cost the same as six eggs form SPAR, plus it wont start to rot and smell after a week rolling round the boot :thumbsup:
#14 MRA
MRA
  • 7,607 posts
Posted 07 May 2009 - 12:09 AM
Yes but if you carry 6 eggs..... when you do break down you can use the steam to cook 5 of them and put the other one in the rad to fix the hole, while you send someone off to get the water to refill the rad :thumbsup: ....... that would be me in my case ;)
