Pro's And Con's Of Rose Jointed Tie Bars And Bottom Arms On A Road Car
Posted 06 May 2009 - 11:42 AM
i am looking to install an adjustable geometry setup soon and was wondering whats best to get.
rose jointed tie bars and bottom arms or regular rubber bushed adjustable ones???
what are the pros and cons of the rose jointed parts compared to the rubber bushed ones??
i realy dont mind extra cabin noise for handling gains etc.
anybody got experience with the roase jointed ones??
many thanks
adam.
Posted 06 May 2009 - 11:44 AM
Posted 06 May 2009 - 11:46 AM
I wouldnt have anything else
Paul
Posted 06 May 2009 - 11:51 AM
I have rose joint top and bottom arms, and rear trailing arms. There isnt any extra noise to speak of. I can get my suspension setup spot on and the front wheels dont change track angle as Im accellerating so I set the front parallel for least scrub.
Paul
so you think its deffinatly worth spending that little extra and getting rose jointed?
am i right in saying that they dont degrade like the rubber bushes so they do not change angles and other settings as they degrade and wear??
have you had to replace any rose joints due to wear? if so how long did they last??
cheers
adam
Posted 06 May 2009 - 12:17 PM
As Paul says, they keep your wheels in check, you also get better turn in
And contrary to some strange belief they do NOT wear out any quicker than say a steering control rod end does....... the only time that wear is an issue is when the lower arms do not have a dust boot.
A proper dust boot is one that covers the whole joint in 360 degrees not just a side cap which still lets in dust and water
My own are almost twenty years old, made as part of my apprenticeship
Regards Martin
Posted 06 May 2009 - 12:18 PM
Paul
Posted 06 May 2009 - 01:41 PM
Posted 06 May 2009 - 03:42 PM
