Car Trying To Start After I Switched The Engine Off
7 replies to this topic
#1 westpark15
westpark15
  • 133 posts
  • Local Club: mini drivers club
Posted 06 May 2009 - 04:46 PM
Model:neon
Year:1991
well the problem only seems to happen every now and then.
but when i switch the enigne offt the car trys to start back up again
does anyone know what could be causing this probelm ?
and how to solve it
thanks nigel
Any non-standard parts that might be involved with the problem?
#2 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 06 May 2009 - 05:00 PM
That'll be called "run-on" - the fuel is being ignited without the spark. Is the car running rich? Have you checked the timing?
#3 satvinder
satvinder
  • 557 posts
Posted 06 May 2009 - 05:20 PM
as said this is run on. Normaly timings out. May aswell check valve clearence. My mini does this because is runnig way to rich due to a incorrect needle.
#4 westpark15
westpark15
  • 133 posts
Posted 07 May 2009 - 03:52 PM
yes the car is running abit rich at the moment
and also i havent checked the timing
whats the best way to solve it ??
#5 Ouster
Ouster
  • 2,986 posts
Posted 07 May 2009 - 04:30 PM
Get a strobe light on the case, adjust as per Haynes.
#6 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 08 May 2009 - 12:32 PM
My car runs on sometimes if you've been thrashing it about for a little while, even though the mix/timing are spot on. Had it tuned several times by different people and it still does it.
we call it a "cold" and use it as a sign that she's enjoyed herself :thumbsup:
#7 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 08 May 2009 - 12:47 PM
Can also be where carbon has built up in the cylinder head, which glows red hot where the engine has been running. When you turn off the engine, all you are doing is stopping the spark, and as the carbon is glowing it still ignites the petrol from the mechanical fuel pump (pumping still as the engine is still turning over). Sometimes it can just even be carbon on the plugs, so take them out and give them a clean if they are dirty?
#8 RG_16
RG_16
  • 21 posts
Posted 08 May 2009 - 12:50 PM
this happened to my parents' mini still not too sure why
probably running too rich but we just ignored it then about a month later
the car broke down and wouldnt start again.
When we took the engine apart the valve seats had been burnt due to
overfueling meaning we had to replace the whole cylinder head
