Fowling Linkage And Steering Rack Bolt Removal For Drop Kit
5 replies to this topic
#1 t@z
t@z
  • 1,712 posts
  • Local Club: www.turbominis.co.uk
Posted 06 May 2009 - 09:51 PM
problem 1
i won this on ebay http://www.minispare...ty=pb&pid=34220 and fitted it tonight however the throttle linkage on the carb fowls on the back of the inlet and basically wont let it move. is there a shim i can get just to give me an extra few mil to space the carb back more or do i just try filing it a bit
problem 2
i go a drop kit to lower the steering rack however the bolt i am supposed to remove is flat one end and is the threaded end of a bolt the other how do i remove it :thumbsup:
ta
#2 mars red mike
mars red mike
  • 1,500 posts
Posted 06 May 2009 - 09:58 PM
problem 1 - you should have a black carb spacer like this http://www.minispare...ty=pb&pid=37146. This will push the carb back enough for the linkage to clear the inlet
problem 2 - I usually tap the flat end around with a punch and hammer then when its undone enough clamp some mole grips on and undo it that way.
#3 t@z
t@z
  • 1,712 posts
Posted 06 May 2009 - 10:09 PM
thanks for problem 2 i will beat the devil to death :thumbsup:
i thought the one i got had one of these on or is that black one wider, i'll meassue them tomorrow. some more pics just taken below should help more
Edited by t@z, 06 May 2009 - 10:10 PM.
#4 mars red mike
mars red mike
  • 1,500 posts
Posted 06 May 2009 - 10:21 PM
I do vaugely recall have to modify the metal bracket that the throttle and choke cable clips into on my bro's mini but i didnt have any probs with the linkage like that. You could probably file the inlet down abit to clear the linkage. It looks like it only needs a nats whisker taking off.
#5 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 06 May 2009 - 10:31 PM
I've had similar problems in the past, just a quick touch with the mini grinder was all that was needed, a file would do, as mentioned by mars red mike you just need a very small clearance.
Edited by cambiker71, 06 May 2009 - 10:31 PM.
#6 t@z
t@z
  • 1,712 posts
Posted 07 May 2009 - 07:30 AM
thanks for help i thought that was the case but always best to check :thumbsup: will have that sorted friday eve
Edited by t@z, 07 May 2009 - 07:30 AM.
