11 Stud Black, 9 Stud Head?
9 replies to this topic
#1 Clubber Lang
Clubber Lang
  • 746 posts
Posted 07 May 2009 - 03:58 PM
My new head is fubared so looking for a replacement. The block is 11 stud but could i just remove the two studs and fit a 9 stud head? regards Steve
Also do i need to find out what cam i have before i pick a new head? regards Steve
#2 jaydee
jaydee
  • 8,565 posts
Posted 07 May 2009 - 04:13 PM
You sure u've got the right head for ur engine? 11 studs block is a 1275, 9 studs heads are usually 998cc heads, so will be a bit restrictive for ur engine.
#3 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 07 May 2009 - 04:21 PM
its only the 's' engines that have 11 studs. std 1275's have 9, same as 998's
#4 Clubber Lang
Clubber Lang
  • 746 posts
??????????? 1275 = 9 studs as well!
#5 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 07 May 2009 - 04:47 PM
should be fine. or you could have the new dead drilled for 11 stud fitment too.
morris/austin 1300gts also had 11 stud fitment.along with the cooper s
all other 1275 a series(or a plus) should be 9 stud standart.
#6 Clubber Lang
Clubber Lang
  • 746 posts
Posted 07 May 2009 - 10:32 PM
I think engine may have been from Austin/morris 1300gt as the timing chain backplate is a different shape and sticks out the back which i have been told may have been for another engine mount/steady?
Regards Steve
#7 mniguy_nz
mniguy_nz
  • 212 posts
Posted 08 May 2009 - 02:13 AM
Yep I'd say your right. My engine came out of a Riley Kestrel which had a timing backplate with a mount attached to it. As far as I know only 1300GT and S heads are 11 stud. All other 1275 heads are 9 Stud eg. 12G940
#8 Clubber Lang
Clubber Lang
  • 746 posts
Posted 09 May 2009 - 03:17 PM
The head is a 12g940 so will have had the extra bolts drilled. Unfortunately the head is passing water through where the valve springs sit. It is a real shame as seems to have had some serious work done to it recently. It has been skimmed and ported, the valve stems have been turned down etc. etc. It will be a shame to scrap it really.
#9 Asphalt
Asphalt
  • 2,173 posts
Posted 09 May 2009 - 03:41 PM
Almost all 11 stud heads are 12G940 too... Exept of some early FJ/Cooper S heads... Innocenti Minis had 11 studs too.
#10 Clubber Lang
Clubber Lang
  • 746 posts
Posted 09 May 2009 - 04:03 PM
Oh right so this may have originally been 11 stud. Anyone know if this head could be repaired or is it not worth it? regards Steve
