1st Motion Shaft Nut Torque
13 replies to this topic
#1 Guennie
Guennie
  • 186 posts
  • Local Club: Bury Mini Club
Posted 08 May 2009 - 10:27 PM
hey,
i've just swapped my drop gears to straight cut ones and am trying to torque up the first motion shaft nut up to 150lb ft. How am i supposed to secure it, to do it up? i've been trying this evening but cant even get it to 110 lb ft!
cheers,
Guennie
#2 Ethel
  • 26,074 posts
Posted 08 May 2009 - 10:58 PM
I suppose the gearbox is on the engine? The usual tactic is to engage 2 gears to lock the box up, you must have done well to get the nut off!
#3 Guennie
Guennie
  • 186 posts
Posted 08 May 2009 - 11:14 PM
nope, the gearbox isn't on the engine at the moment. removing the old nut was a case of locking the 2 old drop gears or putting a set of stilsons on the other end of the shaft and using a long pole!
i've seen a picture on this forum of a guy that engaged 2 gears and it didn't work out well, a few teeth breaking off! i cant afford to break it!!!
#4 Ethel
  • 26,074 posts
Posted 08 May 2009 - 11:22 PM
I don't see how else you are going to get hold of a shaft on bearings covered in gear hubs.
#5 Guennie
Guennie
  • 186 posts
Posted 08 May 2009 - 11:28 PM
if i was to pop some pot joints onto the the diff and partially mount it onto the driveshafts that are in the car still, i could leave it in gear and in theory would this lock the gear box without putting it into 2 gears. would this work? or have i not made it clear what im thinking of doing?!
#6 MRA
MRA
  • 7,607 posts
Posted 08 May 2009 - 11:34 PM
Do it by the book........... it works ;D
#7 Ethel
  • 26,074 posts
Posted 08 May 2009 - 11:38 PM
In theory yes, but you'd still be using the final drive pinion and whatever gear you put it in. I don't think you'd break a healthy box by engaging 2 gears, it's how it's been done for years.
#8 Guennie
Guennie
  • 186 posts
Posted 08 May 2009 - 11:39 PM
So that would be engaging two gears at once then. I'll have a read into it tonight and let you know how i get on!
#9 Guennie
Guennie
  • 186 posts
Posted 08 May 2009 - 11:41 PM
Cool thanks, for your help. I'll engage 2 gears and give it a go first thing tomorrow. ;D
#10 MRA
MRA
  • 7,607 posts
Posted 09 May 2009 - 12:08 AM
Select 1st and 4th ;D
How does the final drive pinion effect this ?
Regards Martin
#11 Pooky
Pooky
  • 5,691 posts
Posted 09 May 2009 - 05:08 AM
;D
#12 Guennie
Guennie
  • 186 posts
Posted 09 May 2009 - 07:33 AM
;D
Hey Pooky, it was you thread i found earlier and the picture that is making me dread doing this!!!
Hope you've got it sorted now.
Guennie
#13 Pooky
Pooky
  • 5,691 posts
Posted 09 May 2009 - 04:37 PM
Guessworks sorted it out for me! But yup, all sorted now, thanks! I have absolutely no idea what went wrong with mine, just unlucky I guess!
Good luck with yours if you've not done it yet, how'd it go if you have?
#14 Guennie
Guennie
  • 186 posts
Posted 10 May 2009 - 11:11 PM
Woohoo, i got mine all torqued up nicely now :D
