Which Engine To Use?
9 replies to this topic
#1 jamie_gibbons
jamie_gibbons
    Starting My Mini Up
  • 4 posts
Posted 10 May 2009 - 09:28 PM
guys question
whats the best enigne to put in the front of a 1991 mini cooper?
i was told it was possible to put a 1.6 honda civic enigne in the front of my mini cooper is that a good choice?
#2 ECG317W
ECG317W
  • 131 posts
  • Local Club: Wessex MOC
Posted 10 May 2009 - 09:45 PM
You need to have the front end extended to fit a vtec in a mini. Depends how much you want to spend... :D
#3 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 10 May 2009 - 09:47 PM
Small bore vauxhall (something like X16XE) can fit in a standard length roundnose. Frame from Allspeed, drop engine in, modify the bulkhead, uprate the brakes, jobs a good 'un.
Possibly.
#4 jamie_gibbons
jamie_gibbons
    Starting My Mini Up
  • 4 posts
Posted 10 May 2009 - 09:55 PM
so the vauxhall X16XE would be best suited to be droped in the front of the cooper
what vauxhall would these engines normally be fitted to?
Edited by jamie_gibbons, 10 May 2009 - 09:59 PM.
#5 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 10 May 2009 - 11:37 PM
MG Metro?
:D
#6 Ouster
Ouster
  • 2,986 posts
Posted 11 May 2009 - 09:32 AM
X16XE was in many small GM vehicles, including the Corsa. As a result, the engines are dirt cheap. They're also very easy to wire into the mini loom (I think only 6 wires). Vtec engines on the other hand are a lot more expensive, harder to wire up, but provide more power (although at higher revs than the Vauxhall).
Check out http://www.16vminiclub.com/forums/
#7 Cooperman
  • 23,294 posts
Posted 11 May 2009 - 02:17 PM
Best engine for a 1991 Mini Cooper is a 1991 Mini Cooper engine with some nice improvements to give around 90 bhp.
#8 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 11 May 2009 - 02:24 PM
Ok, what you've asked is as very VERY broad question - in no particular order off the top of my head the following engine have been fitted to minis:
K-series, VTEC, Vauxhall, Nissan
Toyata, Yamaha, Hyabusa, Rover V8
VW, Suzuki swift, Diahatsu charade
Metro Diesel
and the list goes on and on - I'd recommend you go on www.16vminiclub.com and read through the website - there's tonnes of people out there doing all manor of conversions and most of the projects are documented with pictures - techincal diagrams -heaps of knoweledge to be had out there.
TMF also has a Non-mini engined projects section which you'll do well to look through - again, tonnes of info there.
Also worth me mentioning that as a bare minimum all of these conversion require a lot of work - bare essentials are Subframe (either a bespoke item or a mini subframe modified to take the engine) drive shafts (need cutting and shutting or again - bespoke items made up) gearlinkages, body work mods depending on where you wish to mount the engine- most round nose minis will need an extended front - clubmans have more room and often do not need modifying.
You could also try searching the site - only a few days ago this thread was created - almost identical to yours:
>>CLICK ME<<
#9 jaydee
jaydee
  • 8,565 posts
Posted 11 May 2009 - 03:42 PM
Why not simply modding your cooper engine? 1991 coopers have a great engine and quite easy to modify :P
#10 Cooperman
  • 23,294 posts
Posted 11 May 2009 - 03:47 PM
It's much cheaper to obtain 90 bhp from the original Cooper 1275 engine than to spend, literally, a fortune fitting a non-Mini engine.
