Blue Smoke On Deceleration
4 replies to this topic
#1 ash
ash
  • 152 posts
Posted 11 May 2009 - 09:52 AM
Hi,
I'm getting a puff of blue smoke when I come off the accelerator, it only really happens when I'm on the motorway though usually cruising around 65, if I'm going faster it's an even bigger puff of blue smoke. Am I right in thinking it is either the oil ring or the valve steam seals? If so, how can I tell? Both sound like rather large jobs.
The engine is a fairly recently rebuilt 1293 (not rebuilt by myself though).
Ash
#2 jaydee
jaydee
  • 8,565 posts
Posted 11 May 2009 - 10:41 AM
Uhm..not sure, but sounds to me like a piston rings fault..
#3 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 11 May 2009 - 10:48 AM
Hi there.
Either of the following will need doing - You Piston rings are shot and allowing oil into the combustion chamber - or - your valve stem seals are letting oil into the combustion chamber...
I would perform a Compression test and see if this gives any clues to the condition off the piston rings - if these turn out ok then it would be an idea to check your valve stem seals - If either turn out to be the problem - you're taking the head off anyway!
#4 Ethel
  • 25,932 posts
Posted 11 May 2009 - 10:51 AM
It does sound like classic inlet valve seal failure.
#5 ash
ash
  • 152 posts
Posted 11 May 2009 - 11:04 AM
Thanks guys :D
Okay, looks like I will do a compression test and check the valve stem seals.
