Hi,
Just a quick one,for those who run the promotive conversion.
How often do the chain and/or sprockets need to be replaced?Also is there anything else that wears out particularly quickly?
Many thanks,Ross.
Promotive R1 Chain Life
rosco454
, May 12 2009 04:05 PM
4 replies to this topic
Posted 12 May 2009 - 04:05 PM
Posted 12 May 2009 - 04:39 PM
Hi,
Many thanks,Ross.
Without scotoiler not that often but i will need to take it off every 2000 & have it checked! with scotoiler & correct tension they last a long long time! the only thing that wears is the tensioner sprocket if its not quite inline! we did have some early problems with bearings & sprockets and twisting this n that but they have all been ironed out now!
Hope that helps
Posted 12 May 2009 - 06:40 PM
Thanks for that,i was looking at the scott oiler kits - think i will get the tourer model with longer distance between fill ups.Seems like it would save a lot of hassle.
I dont mind checking or even replacing fairly regularly just so long as its not ridiculous.
Cheers Ross.
Cheers Ross.
Posted 15 May 2009 - 03:00 PM
would it help if the teeth on the sprocket were case hardened or something?
Posted 16 May 2009 - 11:00 AM
my second chain has lasted very well since fitting the scott oiler, the bigger volume 'tourer' is what I got and I've just filled it up again after approx 600 miles of running. I might have it set a bit 'loose' but its doing a good job
basky's got a good point there - make sure your tensioner gear is sitting in the right position.
not sure about the case hardeneing? all my sprockets look fine and work fine, it was only 1 link in the first chain that failed, made a terrible loud clunking noise.
