Water In Boot!
6 replies to this topic
#1 Mini trouble
Mini trouble
  • 40 posts
  • Local Club: looking for one, near Carlisle
Posted 14 May 2009 - 12:08 AM
I started getting water pooling in the boot when it rained hard for days after, I’ve filled all the seams and water was still in the boot under the tier. I though that I had solved it but as I was trying to get the rust off the bottom of the boot with a weir brush I must have gone throw one of the bungs in the weal well and rusty water stated rushing out!
Where did it come from is there a big space under there where water can sit?
I think I found a hole in the side.
Rover Mini Studio 2 (1990)
Posted Image Posted Image Posted Image
#2 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 14 May 2009 - 05:40 AM
I'd say it's sitting under all that black bitumen goop.
Personally, I'd chip all that out and have a good look at the metal making up the boot floor.
The usual places to go are in the areas behind the arches (inc under the tank) and the battery box.
But you'll need rid of that messy stuff to see properly.
Water might be dripping down from the window, or even from the washer bottle (if yours has a boot mounted one like mine).
#3 Mini trouble
Mini trouble
  • 40 posts
Posted 15 May 2009 - 06:41 AM
Yer, thanks. I will give that a go. Looks like the man I got it off just panted over eaveything. Found a hole in the seam on the inside of the boot yesaday. Looks like it has been running in from there. Going to take it and get a it pached up. Realy shud get a welder.
Eany and all idears are welcomed. Looks like I'm going to need it. Keep finding things little thing rong.
#4 daemonchild
daemonchild
  • 2,341 posts
Posted 15 May 2009 - 06:47 AM
How do the areas surrounding the subframe mounting brackets look?
Are the arches solid - gentle prodding with a screwdriver from inside the boot?
Rear valance and closing panels ok?
#5 daveeeeee
daveeeeee
  • 684 posts
Posted 15 May 2009 - 06:51 AM
Don't prod anything you're not prepared to deal with though! :thumbsup:
#6 Mini trouble
Mini trouble
  • 40 posts
Posted 06 June 2009 - 06:42 PM
Would of been on elier but Net been off.
subframe mounting brackets look in good nic, Think Iv got the leak fixed. going to get a pach weled in when I get all the rust cut out of the corner. water was runing in fron the sem on the rear driversine from the roof, dont on if you can see from the pictuers, but it runs right into the boot. got it pluged.
thanks for all your help.
#7 stormintrooper
stormintrooper
  • 2,072 posts
Posted 06 June 2009 - 07:50 PM
Don't prod anything you're not prepared to deal with though! :P
haha, i did this once with my drivers footwell where it meets the sill, wont be doing that again but then again that was when i bought my henry an all his filler has been removed now anyway :(
