Are Mini/metro 1275 Gearboxes Generally Noisy, If So To What Extent, Many Thanks
5 replies to this topic
#1 samsfern
samsfern
  • 5,243 posts
Posted 15 May 2009 - 09:45 PM
the noise is a wine in 1st and 2nd, and i can only just hear it in 3rd, and when you take your foot off the throttle from about 3-4000rpm, the noise seems to get worse as the engine speed drops, 4th doesnt make the noise when i do the same thing.
its a metro engine (12g) and has a metro box and final draive (3.44)
people say to me mini transmissions are normally noisy, but to what extent???
any help appreciated, many thanks.
#2 Southy
Southy
  • 1,579 posts
  • Local Club: Oldham and Distrcit Mini Club
Posted 15 May 2009 - 09:55 PM
They can tend to be ever so slighly noisy (mainly first as its straight cut) but not to the extent where it can be unbearable, it could be a possibility from your description of the whine in 1st and 2nd and slightly in 3rd that the layshaft is wearing away at the first gear end.
#3 Asphalt
Asphalt
  • 2,173 posts
Posted 15 May 2009 - 09:56 PM
Usualythey'r |<----that---->| loud... :w00t: Do you have a garage with Mini knowlege near you?
Maybe they can listen and tell you. Noise idendification is always bad via words/text... :(
However.... Noise in 1./2./3. but not in 4. sounds like a worn layshaft/gear to me...
In forth the power goes direcly through the mainshaft, in 1./2./3. it's routed through the layshaft/gear.
The layshaft is a known weak spot in a Mini gearbox... But it's comprably easy to fix (still a engine out jobby).
Edited by Asphalt, 15 May 2009 - 09:58 PM.
#4 samsfern
samsfern
  • 5,243 posts
Posted 15 May 2009 - 10:01 PM
it sort of sounds as though its coming from the drivers side though and would i be right in saying that first gear is nearer the timing gear?
#5 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 15 May 2009 - 10:03 PM
Sounds like its just the syncro's just spinning up in 1st and 2nd and 3rd just sounds like gearbox noise. The early A boxes were even noisier than the A+ box you will have.
If you really want confirmation if its just general mini gearbox noise, feel free to bring it down to my workshop in upstreet, Canterbury.
#6 samsfern
samsfern
  • 5,243 posts
Posted 15 May 2009 - 10:16 PM
whens the soonest youd be able to do this? its just a bit worrying because the old 998 engine annd gearbox blew, and im just wooried. when i built a 1275 (well 1310) i had a good look at the gear box for about 2 hours at least, it all looked fine, other than a single tooth missing off what i worked out to be 3rd gear synchro (bronzy coloured thing).
