Clutch Problem!could Anyone Tell What This Bit Is Called?(with Pic)
6 replies to this topic
#1 Lukie-J
Lukie-J
  • 858 posts
  • Local Club: South Devon Mini Club
Posted 17 May 2009 - 01:56 PM
Car: standard 1991 998cc engine.
So I didn't even make it to Crystal Palace on saturday!
Was recovered to a clutch centre and they said this:
Was the problem, (the ring around the bottom should be attatched)
I'm not sure what the bit is called, found what I thought was it, but it's not!
It goes between the flywheel and the inner end of the clutch arm? if that makes sense?
The ring-piece that is broken sits on top of the fingers.
I'm not sure of the technical names for it all.
The fingers are all fine.
Also, I don't know how exactly this would affect the clutch?
It seemed as though the clutch just wouldnt engage..at all. Pumping the clutch didn't work.
Thanks in advance.
I'm absolutely gutted :) :
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 17 May 2009 - 02:23 PM
top hat, its works with the release bearing, if you need one i have a few i can sell
dave
#3 Asphalt
Asphalt
  • 2,173 posts
Posted 17 May 2009 - 02:29 PM
AHU1564... NLA... :) Get a good second hand one.
http://minispares.co.....20PLUS **nl...
Basicaly transmits the pressure from clutch arm via the release bearing to the pressure plate.
#4 Lukie-J
Lukie-J
  • 858 posts
Posted 17 May 2009 - 02:35 PM
Would it be number 12 on Here?
EDIT: that's the one asphalt, although it seems minispares no longer sell them!
Edited by Lukie-J, 17 May 2009 - 02:38 PM.
#5 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 17 May 2009 - 02:57 PM
the diagram i got with part 12 on is not mini? as said source a good second hand one
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 17 May 2009 - 03:19 PM
as said i have a few 2ndhand ones £12 inc post
dave
#7 Lukie-J
Lukie-J
  • 858 posts
Posted 17 May 2009 - 03:23 PM
dave
Cheers dave, I'm gunna have a phone around local places tomorrow.
Will PM you if I can't find one!
Thanks for your help :)
