Engine Position
3 replies to this topic
#1 Minitrio
Minitrio
  • 420 posts
Posted 17 May 2009 - 06:07 PM
I have just replaced the top engine steady bracket and bushes on my '97 MPI, having carried out head gasket change.
When i tried to put the bolt into the side of the engine block, i found that the hole was 3-4mm out of position. To rectify it i had to pull the engine towards the grill, to get it to line up and go in. It took several attempts to lever the engine forward and get the thread to bite and eventually go in.
With the force i had to use, what possible effects will this have on the engine and driveability?
Still have a little work to do before starting engine and driving my mini.
#2 mars red mike
mars red mike
  • 1,500 posts
Posted 17 May 2009 - 07:11 PM
99.9% of the time you have to lever the engine forward a bit to get the bolt in. I've had to do it loads of times but have never suffered any adverse effects
from doing it.
#3 Pauly
Pauly
  • 4,213 posts
Posted 17 May 2009 - 07:42 PM
They are usually slightly out, good like this as it makes the engine more steardy.
Paul.
#4 Minitrio
Minitrio
  • 420 posts
Posted 17 May 2009 - 08:53 PM
Cheers guys.
I was slightly concerned because the last time i changed them, it lined up perfectly.
Happier now thou. Thanks again ;)
